02-25-2015, 09:23 AM | #89 | |
Resident Tamed Racing Driver
300
Rep 4,697
02-25-2015, 09:42 AM | #91 |
300
Rep 4,697
Thanks! It's what keeps me from over modding the 1er.
02-25-2015, 11:32 PM | #92 |
Rep 200
Drives: A Car
What a beautiful ride StIg! Keep us posted.
02-26-2015, 07:49 AM | #93 |
Rep 1,409
Your car is an awesome piece of history and passion.
Looks like it is in the hands of a meticulous owner! R-E-S-P-E-C-T !!!
02-27-2015, 11:11 AM | #94 |
Rep 4,040
Drives: 130i coupé ;)
Those seats are hot. Do you think they will fit in a 1series?
03-01-2015, 02:28 AM | #96 |
Rep 49
03-02-2015, 07:12 AM | #97 |
300
Rep 4,697
Yup. I have a local buddy who is running them in his E90 330i.
05-25-2015, 03:16 PM | #99 |
300
Rep 4,697
Some of the more recent work:
Suspension Overhaul Big update, and one that has been brewing since I picked up the car. Being that it is 30 years old, most of the suspension can safely be assumed to be worn out. While I was ok with the sloppy handling while getting to know the rest of the car, the fear I could break a ball joint and careen into a tree wasn't particularly reassuring when beating on the car. So with that in mind, I replaced: Front shocks Rear shocks 20mm front torsion bars 26mm rear torsion bars Ball joints A-Arm bushings front A-Arm bushings rear Front sway bar bushings Rear sway bar bushings Rear sway bar end links Rear spring plate bushings Rear trailing arm bushings Front shock mounts Rear shock mounts Torsion bar seals Powdercoated all the front suspension parts/rear sway bar Fresh hardware all around When I got all of that in, I had it corner balanced, aligned, and lowered to the Euro ride height. With a full tank of gas she weighed in at 2550lbs, not bad for a street spec 911. Getting prepped with boxes to sort all of the parts coming off and up she goes: Wheel off and front suspension disassembled aside from the strut assembly: Front A-Arms out, which look to be in pretty good shape: Bushings on the A-Arms were completely hosed though(should be an even circle around the arm): But it's nothing that the propane torch can't fix: Sadly, those shot bushings were causing the torsion bars to contact the contact the A-Arms, where they rubbed and caused themselves to rust, requiring replacement. This is why we preventatively maintain! Most of the hardware, like these sway bar brackets, is in pretty good shape for some mild restoration in the form of sand blasting and powdercoating: All of the front suspension parts and the rear sway bar assembled and ready to be driven to my powdercoater: About a week later, I got everything back. They did an absolutely spectacular job, blasting each part, getting a nice even coat, and avoiding any areas that they should like the torsion bar spindles in the A-Arm or the threads on the sway bar brackets. Total cost per part for blasting and coating was $4.60. arrot: With that taken care of, it was time to reassemble the front end. The parts catalogue: The A-Arm bushings and their respective collars have to be assembled at specific angles to provide the proper mounting position for reassembly. It's any interesting game of back and forth as they want to slip off as you rotate them. Nailed it: Everything getting buttoned up in the front, and yes, I put the lock pin and plate in the ball joint after installing it:
05-25-2015, 03:17 PM | #100 |
300
Rep 4,697
And here's where I fail, I forgot to take pictures of the rest of the project. The new torsion bar end levers and torsion bars took long enough to come in that I was a bit focused when everything finally arrived for me to put back together.
First shots during the maiden voyage of the new height and such. She feels absolutely phenomenal:
06-02-2015, 12:31 PM | #102 |
Rep 3,855
How does it drive with all those fresh parts? As tight as the 1?
06-02-2015, 12:38 PM | #103 | |
300
Rep 4,697
All of that is fine though, as I bought with the intent of having a car that is completely different to drive than the 1er.
06-03-2015, 07:07 AM | #106 |
300
Rep 4,697
Thanks gents.
06-04-2015, 12:48 PM | #107 |
Rep 374
I'm really jealous of your garage! 4 car garage + your own lift.
New Car: 2019 Porsche 718 Cayman GTS | Stock for now Old Car: 2013 BMW 128i | 6MT | BMW Performance Grills | CDV Delete | SSK | Performance Exhaust | M3 RSFB | TCKR DA |
06-04-2015, 01:50 PM | #108 |
300
Rep 4,697
Lift is key to safe/capable DIY. Pretty cheap as well, just needs a solid garage floor.
06-04-2015, 08:06 PM | #109 |
Rep 67
Whow, just came across this thread. Makes me want to uncover the 87 911 coupe in our garage. Triple black, basically all stock except for a turbo steering wheel. 117,000 miles and I am original owner. It's in good shape but put to shame by your beauty. I'll have to post a few pics. The work you are doing is amazing.
06-05-2015, 08:05 AM | #110 | |
300
Rep 4,697
