08-27-2016, 11:31 PM | #155 |
Rep 2,643
The cog icon normally means there is some issue related to the DCT gearbox. A mechanic will be able to scan the errror code and tell you more precisely what the issue is.
11-04-2016, 07:49 AM | #156 | |
BMW Fan
294
Rep 847
It seems that apart from the driveshaft, this will be a direct bolt-in upgrade. However, I still don't see how the wheel fitment will be the same. I thought that the hubs and rear rotor hat thickness were big contributors to the 135 having the crazy 52mm offset. So, unless the rotor faces on the M3 rear end up with the same side to side width (rear track), how can the 135 wheels still fit? Thanks in advance. |
11-04-2016, 08:21 AM | #157 | |
Rep 2,462
11-04-2016, 09:35 AM | #158 | |
BMW Fan
294
Rep 847
I guess I'll just throw that into my order list. |
11-04-2016, 09:48 AM | #159 | |
Rep 2,462
11-04-2016, 12:51 PM | #160 |
BMW Fan
294
Rep 847
Found a very thorough write up on the full M3 front and rear swap here:
http://www.babybmw.net/viewtopic.php...e647b939fa2333 |
11-04-2016, 01:34 PM | #161 | |
Rep 2,462
11-06-2016, 02:49 PM | #163 | |
Rep 6,285
FWIW I run genuine M3 ZCP/comp pack rims on my E92 335i with no issues (running 245's up front and 275's in the rear) oh and I have the M3 driveline retrofit. |
11-07-2016, 09:07 AM | #164 |
BMW Fan
294
Rep 847
Jekl, I've found 2 different numbers for driveshaft length after Frankenshafting the two halves. Do you have a spec for this?
Also, thanks to the track width answer. I found the same info elsewhere: rotor face to rotor face, the M3 and 135 are the same, the difference is wheel offset on M3 wheels to push the wheels out and bodywork that is 100mm wider to create the wider track. |
Bimmer TV125.00 |
11-07-2016, 09:19 AM | #165 |
Rep 2,462
11-07-2016, 10:18 AM | #166 |
BMW Fan
294
Rep 847
I'm planning on a full M3 rear end swap from a salvage car. The DCT diff has a 3.15 ratio so that's a nice, small bump for a 6MT 135.
You can easily find the ratios for the other M3 diffs with a quick search but the DCT is the only one close to our cars. |
11-07-2016, 06:20 PM | #167 |
Rep 2,682
The driveshaft length will vary on a few things and I wouldn't recommend making one without measuring the actual length required first.
N54 and N55 gear boxes are different so there can actually be a total of 8 different lengths depending on what combination you use.
11-08-2016, 05:01 PM | #169 |
Rep 2,682
No. It was confirmed just a couple of posts above that the hub to hub (rotor to rotor) measurements are exactly the same on all 135 and M3/1Ms etc. The only change in track width is due to wheel offset.
02-10-2017, 09:23 AM | #171 |
Rep 2,462
02-13-2017, 01:38 PM | #172 | |
Rep 339
You can do the whole subframe but i don't think its worth the trouble, at least it wasnt for me since i had M arms already and adjustable toe arm. Everything is a direct swap, but if you keep M3 brakes then you need to swap the master cylinder too. |
02-13-2017, 02:47 PM | #173 | |
Rep 2,462
02-13-2017, 08:44 PM | #175 |
Rep 1,600
Re: M3 master cylinder.
It's on my list for this year along with the booster, which despite being M3/1M specific all threads suggest it is no different to the stock E82 one. Master swap in Australia is expensive. Alternative is to fit a LHD one and ditch the hard lines to the DSC valve block. Get some stainless braided lines custom made instead. The M3 master is rumoured to be more front biased. Piston/bore diameters remain unknown. |
02-14-2017, 10:28 AM | #176 |
Rep 2,462
oh, nice.
So does that mean if one wanted to, they could use the M3 rear spindle, rotor, and brakes, with a 135i axle? I know the master cylinder may need to be upgraded but just trying to understand if the rear is a direct fit with the stock axel. I know the m3 front spindle will work with my tcklines if I get the adapter they use for the front strut for m3s.
