06-29-2008, 11:22 AM | #177 |
Legend
Rep 158
06-29-2008, 08:07 PM | #178 |
Rep 9,034
Finally got a chance to drive a 135 Step- No manual's in SoCal.
To me, there's definitely lag compared to my 335. If you put it in Sport mode, it launches fine, but is then jerky for daily driving. Maybe BMW could just change the ramp on the accelerator to offset some of the waste-gate changes. Also drove and M3, and that thing just drives so nice. Took a turn in the M3 that it handled with ease, but the 135 was getting DSC kicking in with understeer. Surprisingly, the delay in shifting was much better in the Step compared to the DCT, meaning when you pull the lever, there's a definite delay before the gear change actually happens. The actual change is very fast, but you need to pull the lever about 1000 RPM sooner than when you want to shift because that engine just revs so fast. It's an amazing engine. |
06-29-2008, 11:20 PM | #179 | |
Rep 96
MY JET BLACK BMW 135i
Options: ZSP, iPOD, Comfort Access, Heated Seats, Premium Hi-fi Stereo Current Mods: COBB AccessPORT, Riss Racing CDV, Shadowline Grills Upcoming Mods: Window Tint, Quad Exhaust |
06-29-2008, 11:40 PM | #181 |
Rep 29
I'm not sure what everyone expects from their car. to say it lost its low end grunt is just absurd. most people here are stating their opinion without having driven the car before and after the switch, so maybe it would be helpful if someone could describe how things changed for them, like in everyday drivinh situations...
06-29-2008, 11:49 PM | #182 | |
Rep 96
I personally have the old software installed so again...I can't personally say for sure.
06-30-2008, 07:34 AM | #185 | |
Rep 478
But when buying a performance oriented car, yes, everything matters. Not to mention the fact, that the car may not perform the way it did during influential reviews OR even worse, actual test drives. I do think we need to wait and see what pans out in the end here, but it's totally legit to be wary because of ECU issues. |
06-30-2008, 08:17 AM | #186 | |
Rep 7,589
Drives: '19 M2C
Is your 335 Manual?
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
06-30-2008, 08:30 AM | #187 |
Legend
Rep 158
06-30-2008, 08:40 AM | #188 | |
Rep 5,970
Right, but all V81 units will have the newer software. He's just never compared his car to the older ones to realize the difference. |
06-30-2008, 09:40 AM | #189 |
Rep 352
would not call it turbo lag
I just put 200 mile on my 135 that I picked up Friday night. There is definitely a difference in the turbo response in my new car from the 1s and 3s I have test driven. I think a lot of the back and forth is because people using the term “turbo lag” to describe what is happening. Personaly it feels more like the spool up of a supercharger than turbo lag. The turbo doesn’t kick in hard like traditional turbo lag. It seem to be spooling up a little slower (more like a supercharger) than on the old software/ecu . To make it a little more confusing, it seems to spool up is related to two variables RPMs and throttle depression. My guess is the ECU is using how far you are pressing the gas in the equation that it is using to open up the waste gates. If you use a light foot it seems as if the turbos spools up slower. I feel the difference under 1800 rpms and it is only slight when I drive normally. I have a manual and a heavy foot. When I lighten up on the gas pedal the slower turbo spool up is more pronounced. I noticed the spool up of the turbos all the way to 2800 rpm.
I spend very little time under 2000 RPMs and I am aggressive with the gas pedal so I don’t have an issue. My guess is that it would show up the most for mild drivers in automatics. It seem that since the throttle is in the equation, the more you look for this issue by pressing softly and more controlled on the gas pedal, the more pronounced the issue becomes. I will be putting a boost gauge on my 1 in the next week or so to get data. This all based on impressions not hard data so take it with a grain of salt.
Crimson Red 135i, sport pkg ,blk leather delivered 6/27/08
06-30-2008, 09:54 AM | #190 | |
Legend
Rep 158
06-30-2008, 09:56 AM | #191 |
Legend
Rep 158
06-30-2008, 09:57 AM | #192 |
Rep 9,034
My 335 is also Step. It's technically the wife's car, but I drive it 3 days a week that she doesn't work. The 135 will be a manual.
What gargoyl said about the throttle position seems to make sense since it felt pretty good in sport mode, but was stuck in mud in the regular mode. |
06-30-2008, 10:28 AM | #193 | |
Mein Führer! I can walk!
45
Rep 822
Doesn't reg mod start in 2nd gear? |
06-30-2008, 01:05 PM | #194 | |
Rep 7,589
Drives: '19 M2C
06-30-2008, 04:00 PM | #195 |
Rep 9,034
From what I understand, all BMW Step's start in second gear. Is the 135 step program different? I've heard the slush-box is different from the 335, but that was only 1 source I read.
06-30-2008, 04:51 PM | #197 |
278
Rep 6,510
Wow... ok... yes, sometimes the car will start in second gear, but here is WHY:
2 reasons... 1. You drive like a granny and your transmission adapted to think you like it to start in second gear (only does this in D mode) 2. You were driving in manual mode in a higher gear, and come to a stop without downshifting The steptronic while in manual mode will ONLY shift on its own under 3 circumstances... 1. If you hit the kickdown switch, it will downshift 2. if you get below ~900 rpms, it will downshift automatically to one lower gear, to keep the enigne from bogging, or needing to disengage the torque converter (which is fully locking)... it will only do this down to 2nd, to get to first, you have to manually downshift into it. 3. if you hit the rev limiter, it will upshift. So in other words... its all in your control as long as you know how to properly control it. |
06-30-2008, 05:11 PM | #198 | |
Rep 2,626
I meant lag. However, the weight difference isnt as big as you'd expect. I believe it weighs about 80lbs more than an E90. There MIGHT be a slight difference in the 1500-2300rpm range, but not as drastic as people say. Still a LOT less lag than any other performance oriented turbo car I've driven. I'll bet your average driver couldnt even feel the difference. Furthermore, it is only noticable when you NAIL the throttle. At part throttle, there was no difference that I could detect. Not in the slightest. The only time I could see it being an issue is exiting a corner at full throttle in the wrong gear. This whole thing is overblown when it comes to turbolag, IMO. People are being dramatic. If no one suggested to you that there was additional lag, I'll bet maybe 1/20th of the people driving would even notice. It REALLY shouldn't matter to step owners. The car should donshift for you if you hit the gas hard enough at the efrectede RPMs, rendering the issue moot. Furthermore, anyone who cares about 2/10th of a second difference in response wouldn't even be driving a step. The tuning protection is another issue. Honestly, I dont understand why people expect to keep a driveline warranty after making major mods. Its a unique phenomenon to BMW it seems, no car I've owned previously have owners thought like that. You gotta pay to play, and if you break it, you buy it. Quite frankly, if you want BMW to warranty the car, leave it the way they designed it. I dont understand the whole warranty thing. My biggest concern with v81 is throwing limps. I'm not going to ask my dealer to foot the bill when my turbos eventually go after running them much harder than MHI reccomenss.
'08 Black Saphire/Black Z4 M Coupe
RIP Gretta: Blue Water/Lemon 135i. Died to save me. -ChuckV |
