05-28-2015, 06:31 PM | #1 |
Rep 1,963
Will they fit?
Hey guys! I am looking at the VMR 810 flow formed wheels but am not sure if these will fit without rubbing the suspension.
The sizes I am looking at are 19x9.5 et33 with PSS 255 and 19x11 et35 with PSS 295 on stock suspension. A lot of the M3 guys run 19x11 et33 in the rear with 295 or 305 tires so I don't think the rear will be an issue but I am worried about the fronts. Do you think the wheel being 8mm closer to the suspension in the front will be an issue? Thanks! |
06-06-2015, 10:41 AM | #2 |
Rep 167
Definitely fine in the front. I run a higher offset with a wider tyre so no issues in regards to strut clearance.
The rear you might run into a problem though. You will probably need a lower offset or spacer because there's a good chance it will hit the rear crossmember bracket or the shock. |
