05-03-2017, 05:56 PM | #1 |
Rep 3,722
Likely need a new battery, any suggestions for battery and coding options??
Lately my car has been pretty sensitive to use without being on, ie; cleaning the interior with lights/etc on for 10mins without the car running. I did that twice now and then the car would not start.
So I'm guessing it needs a new battery and could use some suggestions on the type of battery and how to get it coded in without blowing a ton of cash on it. Any input appreciated! Also yes, I have searched the forums before posting this... This is one of those cases with TOO much info and not a lot of solid answers.
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq |
05-03-2017, 08:41 PM | #2 |
Ex '87 Carrera
251
Rep 1,259
I just went to Pep Boys and popped for a Bosch AGM platinum 94R800BAGM batt listed as compat for the car. List was ~$220, but with a store coupon, I ended up paying $165. It's a little heavier than the stock Varta, but higher capacity as well, so I like it.
As for coding, you can go the easy route with carly, or there have been much more explicit postings here for using NCS and Tool32 IIRC. You'll need to register a new battery, plus code the VO if you elect to go with a different type and capacity than stock. Seek and ye shall find. Good luck! ianc |
Dackelone10757.00 |
05-03-2017, 09:05 PM | #3 |
Rep 428
Go the BMW store and get them to do it, the new factory battery will last 6-8 more years, like the OEM in your car did.
Do you run a battery tender on it when you are away for 2+ days? I do. I have a 2010 128i. The battery seems strong. Last edited by sixburgh; 05-03-2017 at 09:07 PM.. Reason: mispelled |
05-04-2017, 08:12 AM | #4 |
Rep 893
I installed a battery from the dealer and registered it myself (didn't see any benefit to screwing around with a different battery and coding).
My 6MT came factory with a lead-acid battery, not AGM. We beat this to death on this forum a few years ago... but I wonder if the 6MT cars don't have IAC (and therefore don't use an AGM battery)? I'd be interested to know what the OP has (take it out only after the car is totally asleep and shake it... a battery that sloshes is lead-acid, one that does not is AGM).
2011 135i MSport 6MT AW/black, 72Kmiles, bone stock, moneymoneymoneymoneymoneymoneymoneymoneymoneymoney I LOVE THIS CAR
Dackelone10757.00 |
05-04-2017, 08:22 AM | #5 |
1Addict
3424
Rep 8,045
I'm using the OE Mini Cooper/Z4M battery. Got it from the local mini dealer for $115 before core charge. Think it lists for $145.
Daily: E82 Mutt
05-04-2017, 08:36 AM | #6 |
Rep 31
When it's time for me I'll go to my local mechanic and have him install an Interstate. His supplier always rotates his stock so it's fresh, returns are
no problem, he deals with the core and he does the install. Additional cost is nominal for something you rarely have to do. I think why screw around with this yourself. |
05-04-2017, 09:29 AM | #7 |
Rep 3,281
@bmw1racer
Use the carly app for iphone to register the battery. There is already a DIY thread on this. Easiest method thus far!
05-04-2017, 02:14 PM | #8 |
Rep 556
Go to interstate batteries and ask them for a "blem" of the size battery you need. These have all the specs of a regular battery but would have some kind of blemish on it. $79 and includes 18mo warranty. Super good and cheap!
Gray_Panther1697.00 |
05-06-2017, 07:14 PM | #9 |
I like turtles!
753
Rep 719
based on personal experience (in the VW world), get a factory battery and have them code it. You wouldn't believe how many people use to come into the store with weird electrical issues, and half the time an original battery would solve it. Its just not worth the potential headache, and its not like its something you change that often anyway.
05-06-2017, 09:06 PM | #10 |
Rep 675
Drives: 2010 128i, manual, sport pkg
I bought a factory battery from getbmwparts ~$160 and use bmwlogger to register it.
2010 128i manual, sport package, performance exhaust, Vorshlag camber plates, Bilstein B6 struts/shocks, 245/40/17 ZIII square on et 40 with rolled rear fenders.
05-07-2017, 11:11 AM | #11 |
Rep 460
I doubt you need a battery. It is simple to test it. The net has a ton of instructions just using a simple multi-meter.
If you do need one, Autozone has the correct one for around a hundred bucks. Any indy can code it for you for a couple of bucks. |
05-07-2017, 11:45 AM | #12 |
Rep 61
With all the electronics on these things I also went with a platinum AGM battery at autozone. Swapped it in the parking lot with their tools and had my indy code it.
3 year full replacement warranty, $190 out the door. |
05-08-2017, 09:29 AM | #13 |
Rep 331
Get some good conventional/AGM battery from whatever you want.
Register with carly app. It's so simple. I put Interstate lead-acid with matching spec in my 135i. It runs for a year with no problem. The dealer found my 135i has a aftermarket/ non-OEM battery when my HPFP went out and suggest me to pay them $500 to replace an oem battery with coding. I told them go f*** yourself.
Past: E82 135i Crimson Red | MPE | MHD Stage1+ | Dinan Camber Plate | LCI Blackline | Bavsound stage 1 | KW Coilover V2 |
Past: E93 M3 Vert Alpine White | Remus Sport Exhaust | Past: F82 Yas Marina Blue Civic M4| MPE V2 | DP | BM3 | Apex FL-5 | MP Part(s) | Current: F87 M2 Competition Long Beach Blue | Completely Stock | |
05-11-2017, 06:33 PM | #14 |
Rep 3,550
There is absolutely nothing special about a battery from the dealer other than it will fit and be the right amp hours for the car. If you use NCS Expert you can see what our car has by reviewing the setting. The rating BMW uses is not something advertised for batteries in the US but it can be calculated from the reserve rating. If you are willing to do a little work you can save a bunch of money.
My battery is still working fine on my 2009. I've never used a trickle charger on it and it is only driven 2-3 days a week. I think the BMW charging setup is helping the battery last. So I will use a stock size replacement and code. I will use NCS Expert if I can find my cable and buy Carly if I can't. Even buying Carly will cost less than having a dealer do it. But if you want a simple no hassle way to replace a battery and are not worried about paying a bit more, the dealer is a reasonable way to go. But for those of us with the ability and inclination to save money, this is an easy way to do it.
05-11-2017, 10:12 PM | #15 | |
bimmerphile, technogeek
1005
Rep 3,792
Drives: 2012 E82 6MT Sport
Now I've taken the OCD approach and have my car on the trickle charger on a daily basis.
05-12-2017, 08:34 AM | #16 |
Captain Dutch Rudder
205
Rep 2,258
Wait 2013 and you need a new battery..?
Did you check the life indicator on the battery? My 07 E92 was still strong on the original factory battery 8 years later.
No more E92 or E82
05-12-2017, 11:11 AM | #18 | |
Rep 556
05-12-2017, 11:28 AM | #19 |
Rep 3,722
You still need to tell the system a new battery is in right?
05-12-2017, 12:17 PM | #20 |
Rep 3,722
Ok so this time the car would not start but I checked the gauge on the battery itself and it was green for "sufficiently charged". I hooked up my fiance's car and was able to jump it without an issue.
Any thoughts on this? Seems odd that the battery would say it's charged but not be able to start the car. Also I haven't noticed any issues once it's running so I don't think it's the alternator or other similar issue.
05-12-2017, 12:29 PM | #21 | |
205
Rep 2,258
Have you scanned for any fault codes?
No more E92 or E82
05-12-2017, 01:36 PM | #22 |
Rep 3,722
Haven't scanned yet but will this weekend, I got a couple warnings on the dash while trying to start it but I think that's most likely just the system hitting unexpected voltages and getting confused. One was for ABS and the other was for increased battery discharge while stopped. The increased battery discharge one showed up only once a week ago, has not shown since so I don't think that's relevant.
Tags |
135i, battery, coding, dead |
