04-27-2019, 06:06 PM | #1 |
Free Spirit Tattoo Racing
11
Rep 49
Bathurst Update
Hey guys, thanks for all your support.
Regarding our Bathurst campaign, it was indeed a weekend of highs and lows (as it always is). After discovering a pool of water under the car on Saturday morning, we diagnosed a leaking radiator, and replaced it with our spare stock radiator. Car ran well with no leaks, until the drain plug shot itself out (note to others, lockwire your drain plugs!) and the car overheated. We were stranded at the track with now two leaking radiators. We managed to have the aluminium race radiator repaired at a local shop, however come Sunday morning there was another pool of water beneath the radiator. After scouring high and low for replacement radiators/drain plugs, and only a few short hours until the race, the decision was made to go the trusty radiator stop leak in a bottle. Given that the engine was shot already (due to overheating), we weren't too concerned about any adverse effects, and just prayed that the stuff would do what it said on the label. After doing the thing, there was still a small leak present. In the meantime we had puttied up the stock radiator with plastic putty, and the plan was if the aluminium radiator continued to leak we would swap it out mid-race. The decision was made to start the race from pit road, and after turning one lap we came into pits to check the radiator. It was not leaking at all, and after discovering that the stop leak had performed flawlessly, we hit the track again and completed the full 6 hours!! We finished the race in 19th spot (after starting dead last in 45th), and 6th in class. We were so happy with our achievement, after the radiator was leaking water when the car was fired up and took the track. So now it's time to fit a new motor, new cooling system, and the various necessary improvements that you always find need to be made during the weekend. I will be posting up many questions over the next few months regarding performance mods, and other such things. We really appreciate everyone's help with the brake homologation. They worked so well and we were out-braking pretty much everybody (even taking a lot of faster cars by surprise). |
04-28-2019, 06:00 PM | #3 | |
Rep 3,148
Would highly recommend spending some effort coding out the crap in the DSC system that really interferes with track driving. I've coded this out on my E82 135, basically helps removing the DSC intervention that occurs even with DSC fully off. Really makes it annoying to drive on track, the 130i would have a lot of these 'features' that hinder performance as well. Brake fade compensation - DSC pump increases pedal pressure Brake pretensioning - When you lift off the throttle sharply then get onto the brakes, the DSC increases pedal pressure, results in inconsistent pedal Brake disc drying - Applies light pressure to the brake discs to clear water when wipers are on Power reduction on brake overheat - Reduces the engine power when the calculated brake temperatures are too high Dynamic braking control - applies more pedal pressure at higher speeds And many more: https://www.1addicts.com/forums/show....php?t=1216642
04-29-2019, 06:02 AM | #4 | |
11
Rep 49
Awesome mate, what sort of track use you looking at?
We have noticed several 'nanny functions' that the car has, most noticeably the inability to rev-match when braking hard and the trailing throttle/laggy reapplication. I have personally noticed that braking is inconsistent lap after lap, even on the same corners under the same circumstances. We will be putting a new motor in (now that the current one is cactus), along with headers (if we can find some RHD-suitable ones), and then looking to have it tuned (because I imagine there is something to gain here). We were thinking at the same time of having the tuner disable all the silly things that are going on in the background (although I had no idea they were so numerous in their amount). I will be posting up threads regarding each of these things, if I can't find any existing information using the 'search' function. Driving my old 308-powered HQ touring car gave me a lot less computer intervention! |
04-29-2019, 10:56 PM | #5 | |
Rep 3,148
Throttle issues will be part of the engine tune, these cars have ecu tables in them to artifically lag up the throttle to make the car feel less jerky, but it really dulls the throttle response. Hopefully your tuner has access to the OLS file for N52 to be able to zero these out.
05-01-2019, 02:05 AM | #6 | |
11
Rep 49
We do not have a tuner in mind as yet. I am sure there would be a general consensus as to who would be the best for the N52? We would be happy to travel for a great job. |
12-18-2019, 02:35 PM | #8 |
Rep 2,139
Drives: 2009 e92 335i MSport DCT
FYI you can flash the M3 DSC on the 6cylinder DSCs
PeterY outlines what you need to know. You can also mix and match the calibration. https://www.e90post.com/forums/showthread.php?t=1598910 Best of luck looks like it's a blast!
When you doppelkaplung you doppel your fun.
