07-05-2019, 07:41 PM | #1 |
Rep 616
Spring compressor mistake - ratchet tool is stuck
So being a newbie to this tool (made all necessary safety measures), I mistakenly used a box end ratchet (not open-ended) 19mm and as I tightened one compressor, the box end got stuck under a coil Can’t take the tool off! To make matters worse, it is stuck in the “tightening” direction. More I move it, it gets tighter. I stopped short already, just so I have a bit of space in case I have no choice but to cut the compressor. But this poses risk of course since the spring is compressed. What an idiot I am
Hopefully that made sense. I used the run of the mill OEMtools brand compressor and realized that it “barely” fits on a Swift front spring. I still insisted and was able to get it in there but the other pair can barely “bite” the spring so now it’s all lopsided, biting on one side and stuck to the new strut. Is there a way to get this without cutting the thing? Help! Last edited by $iriu$black; 07-05-2019 at 07:49 PM.. |
07-05-2019, 11:16 PM | #2 |
<(O0=[][]=0O)>
762
Rep 1,199
Springs flex. Probably take a bit of leverage, but it looks like you've got some room to move it out of the way of the wrench, at least long enough to unstick yourself.
07-05-2019, 11:31 PM | #3 | |
Rep 616
I don’t have a bench vise that will help with leverage which is too bad. I was thinking of a way to open or spread that gap up, but again, my idiot mind ran oit of ideas. Clearly I’m a novice in this area🤦🏻 Someone told me to just cut the wrench close enough so it will not spin, then use another wrench since there’s enough of the nut still exposed to loosen it. Cutting the compressor itself is not a good idea I keep telling myself. Last edited by $iriu$black; 07-05-2019 at 11:43 PM.. |
07-06-2019, 04:39 AM | #4 |
Rep 695
Do not cut the compressor! That spring is under hundreds of pounds of load. You will almost certainly hurt yourself if you cut the compressor. All that energy stored in the spring will be released suddenly. You will have a spring, two halves of a spring compressor, and a cutting tool all flying in different directions.
I do think cutting the ratchet as short as possible, then using a different wrench on the exposed part of the nut is the right move. But cutting tool steel isn't fun, and less fun when there is a compressed spring attached to the tool. And even less fun without a vise. Whatever you do, be careful. A shop might be better equipped to get this done safely. |
07-06-2019, 06:05 AM | #5 |
Rep 3,071
Can you use the other spring compressor to take some of the pressure off? or a ratchet strap to take some pressure off so you can release the other one?
07-06-2019, 08:15 AM | #6 |
Sideways and Smiling
3029
Rep 2,860
Drives: In Exuberance
I don't have a solution for you other than to get another set of compressors to take the strain off of the stuck one.
I have to ask though; why are you using spring compressors on coilovers? My Öhlins have plenty of thread to completely unload the spring for installation/removal purposes...
b1aze565.50 |
07-06-2019, 08:30 AM | #7 | |
Rep 616
But I already ordered a different type of compressor that will hopefully free me out of this stupidity. Seriously though, i used it coz all the vids I watched used one not even thinking that mine is different I’m the worst DIYer. |
chris_flies3028.50 |
07-06-2019, 09:21 AM | #8 | |
Rep 2,807
07-06-2019, 03:12 PM | #9 | |
3029
Rep 2,860
For example: not putting thread-locker on ring gear bolts
07-06-2019, 06:32 PM | #11 |
C2H5OH
3935
Rep 2,146
07-06-2019, 07:01 PM | #12 |
Rep 616
I actually planned to get one like that from Eastwood. But the one I got is still a “claw” type with smaller contact points. Hopefully I will compress on the opposite side of where the stuck compressor is, free up the ratchet (Im expecting the spring will open up a bit and lower down from the topmost part of the coil) and then loosen it up.
07-06-2019, 07:05 PM | #13 | |
Rep 616
I believe I don’t quite understand the double nut method on the bolt side i mean I’ve done double nut methods on installing studs on wheels but that’s it. Sometimes I find myself as such a black-or-white learner. I literally need to see someone do it on a video so I’ll learn how to do it. That’s how I self taught myself in working w cars. YT has been a great aid as well as our forum. |
07-06-2019, 07:16 PM | #14 | |
Rep 616
Problem too is since the spring is so narrow, having the compressor clamp on to one side of it pushed it stuck into the shock body so it’s harder since I’m working with the strut along with it. |
07-06-2019, 10:49 PM | #15 | |
Rep 2,807
And as others have said, don't feel bad about a mess up. We all have done them - just some of us don't mention them all.
$iriu$black244.50 |
07-07-2019, 08:07 PM | #16 |
Rep 5
Yep, don't feel bad.
I work on aircraft and have had mates do the exact same thing removing a component with those spanners, lots of tricky manoeuvring and swearing involved to fix the situation 😂 |
$iriu$black244.50 |
07-07-2019, 10:11 PM | #17 |
Rep 616
Solved
Thanks to all for the sage and useful advice.
I've used another set of spring compressors with smaller claws, freed up the coil from the strut. Then, with careful planning this time, positioned the new compressor on the coil to free up a gap above the ratchet. Swore to myself never to use that compressor again. Glad I did not have to cut anything, my tool or god forbid the compressor. My tools are mostly of the GW brand, not expensive but not cheap either. As chris_flies said, I screwed the height adjusters low enough to tighten the top nut and used a 5mm hex to counter. Still have to torque it down to spec. |
07-08-2019, 06:16 PM | #19 |
Rep 2,232
I've always used a socket to do the actual turning of the compressor (on an impact gun, a little at a time each side), and a wrench just to hold the other side (conventional wrench, not ratcheting).
