11-23-2019, 06:11 PM | #1 |
Rep 2,205
128i GM torque converter input shaft seal leaking
anyone replaced the input shaft seal on a gm automatic? I just completed a engine swap on a 2008 that had a bad n52. I think I damaged the seal when I installed the torque converter it's leaking pretty bad.
TIS notes some special tools needed, not sure if they are really required or a normal seal driver set is enough to get it in and out. crossing my fingers that this is all that is wrong with it!
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten.. 1974 2002, many various 3s. |
