10-12-2021, 07:22 PM | #1 |
Rep 144
coding airbag module srs
SOLVED!!!!
Changed out srs module with the one in my parts car e88. didnt need to code it as it auto filled out the vin and what not. also had to replace the roll over module, the driver side seat belt (it was scrunched up on the part that is under the buckle and looks like an accordion), and the yellow wire that connects to the driver side seat belt had come undone giving off a "seat belt limiter" code ================================================== =========================== I just installed a used SRS module from a car that was never in an accident and am now getting the following fault codes (via INPA): 01 mrs 9402 e0 93a9 e0 93b2 e0 9423 e0 when i plugged in the SRS module and ran ISTA + it was green on the tech tree but then became yellow with the same codes. I assume this is because this module was not coded to my car? Any idea on what to do? Thanks. Last edited by lvfb; 10-18-2021 at 02:57 AM.. Reason: SOLVED |
Tags |
airbag, coding airbag module, coding srs, light, module, srs |
