10-22-2021, 11:55 AM | #1 |
Rep 63
Shaking/Vibration Under Acceleration, Need Help
Experiencing shaking/vibration that only last for a short period of time, about a second, when I accelerate under specific scenario. The vibration and shaking is akin to driving over the grated floors on the shoulder the highway, the entire car shakes. There's absolutely no code being thrown either. Nothing happens if I'm coasting, accelerate hard/fast, in sports mode, or WOT, only happens with gradual acceleration. It occurs mostly between 20-60MPH and 1600-2300RPM, within a 200-300RPM range depending on speed.
This has been happening since I had my AA headers installed.... Not sure if there's any correlation there though. Doubt it's a misfire because of no code and I popped my coil and plugs out. No oil and they're clean. Both coils and plugs were replaced about 6K miles ago. No air leaks either, according to my tech..... Doesn't feel like the car loses power when it vibrate or shake either, as RPM continues to climb and the car does not slow down or stall. It even shook my intake boot off. My car is a N52 128i Automatic, and here's the mod list:
Going to try replacing engine and transmission mount this weekend and if I have time, transmission fluid as well. These are some of the quick fixes I can find scouring the internet. Though, other people's symptoms are similar, but not the same as mine. Finger crossed on it working. Honestly, been pulling my hair out trying to figure out what the issue is, especially with the lack of code. In the case the above does not resolve my issue, any other suggestions? P.S. Gonna be cross-posting this to garner more attention, hope no one mind. Last edited by WgSo; 10-23-2021 at 06:23 AM.. |
10-22-2021, 06:56 PM | #3 |
Rep 63
10-22-2021, 08:13 PM | #4 |
Rep 93
Drive shaft: Check flex disc, u joints , center bearing and center bearing carrier
Cv axel : check the boots see if they are torn, leaking "make noises when turning? Clicking or knocking sound" All these things can be referenced on the inter webs/ YouTube. Hope this helps |
10-23-2021, 01:48 AM | #5 | |
Rep 277
Did you change coils also 6k miles ago or just plugs? Have you changed or cleaned your vanos solenoids recently? Or the vanos filters? Honestly it sounds like a coil that's on its way out like mine. When you checked the coils did you see if there's any cuts or tears along the sides of the coils? I noticed on two of my coils that failed there was a small tear along the sides. I don't know if it was related or can cause an issue but my reasoning was maybe the coil wasn't holding a charge because the metal inside was touching or near the metal of the spark plug tube. I have no evidence or info to support that, it's just what I assumed happened because both failed ones had something similar. |
10-23-2021, 05:21 AM | #6 | ||
Rep 63
I did get a misfire one time in cylinder 3 with code, but when I swapped the coil to cylinder 2, there was no more issue since. I just chalked it up to not reinstalling it properly when I did my valve cover gasket and MILVS because when I swap to cylinder 2, I took great car in getting all the air out and seating it by twisting it as much as I can. Guess I can try to swap it back to cylinder 3 and see what happens. If that throws a code, I can replace that coil or plug.... Nope, did not touch the vanos solenoid or filter. Getting mixed information on the solenoid being cleanable or a straight up replacement part. Didn't want to risk having to replace it by taking it out and messing with it. As my car is only 14K mile, didn't think it warrants it. |
10-23-2021, 10:48 AM | #7 |
Rep 86
Drives: 08 128i E82 & 09 328i E93
I'd look at the coils for sure. Try to keep it sputtering til it throws a code, that's how I found mine a while back. Got to the point I could make it happen on command and the misfire would stay till I restarted the motor.
10-23-2021, 11:50 AM | #8 |
Rep 63
That's very difficult because staying within that 200-300 rpm increment only last a split second. Inside try to make it stay in that state for as long as I can. No code. Kind of scare of doing it too often as it actually cause my intake boot to come off, which caused another issue ....
10-23-2021, 04:15 PM | #9 | |||
Rep 93
10-23-2021, 06:13 PM | #10 | |
Rep 63
10-23-2021, 06:21 PM | #11 |
Rep 93
Off topic
With the set up you have milvs, AA header, stage fp tune etc.How much of a noticeable performance difference did it make vs stock? And did you have any idle issues after the tune was first flashed? |
10-24-2021, 09:49 AM | #12 |
Rep 63
I did all those mods at the same time and I can only describe stock with one word, SLOW. No idling issue on my end.
carscatscoffee15257.00 |
11-07-2021, 11:41 PM | #14 | |||
Rep 277
The vanos filters are difficult to get to, you can find videos on YouTube but they are on the passenger side of the engine in a spot that you cannot see so you need to find them by feeling around. I don't think those are your problem per se but it's possible they are on their way out and not actuating correctly. Like someone else said try to keep it sputtering till it throws a code, I realize it's hard to do that but try pushing the gas harder when it's doing that or let off and then hit the gas or some combination to make it throw a code, otherwise we're just throwing darts at a pic of an engine on the wall and hoping whatever it hits is the right answer. The alternative is the expensive route of just changing everything until the problem goes away |
11-07-2021, 11:45 PM | #15 | |
Rep 277
Desertman had a few pics of how to lifte the engine using the cars tow hook connected to the engine and some kind of chains. I'd go that route over lifting the engine on the oil pan. |
01-29-2022, 01:10 PM | #16 |
Rep 63
Just want to report back, almost forgot about it, that my issue was resolved with a transmission fluid change! Do want to mention that it will take a couple of hundred miles of driving after the fluid change for it to go away. You'll noticed that the shuddering/shaking will be a lot less and infrequent right after the fluid change compare to prior. In my case I can no longer replicate it as it happens randomly. It will slowly happen less and less as you rack up mileage to the point where it won't happen anymore. Hopefully this information can help anyone that may be experiencing the exact issue I had.
05-09-2022, 11:31 PM | #17 | |
Rep 437
Second this highly. It's like giving your 128i a red bull. Car becomes lively. Drives beautifully. I have a similar setup, FBOs, but I had my car dyno tuned at Stage.
Mods Done: AA Exhaust/Headers | 3SIM | MILVs | StageFP Dyno Tuned | Euro Box Intake Swap | LCI Blackline Tailights | OEM Euro Bi-Xenon Swap from Halogen | Rear Bumper M-Sport Swap | Rear PDC Retrofit | BMW OEM CF Diffuser/Spoiler | BMW Front Aero Kit | Supersprint Sec 1 Cat Delete Straight Pipes
To Do: Ohlins R n T Suspension | Front/Rear Sway Bars | M3 Front Control Arms/Bushings Eventually: AT -> MT Swap (!?) |
08-24-2023, 02:28 PM | #18 |
Rep 1
128i shuddering under acceleration
I've been having this problem on my automatic 128i for around a year. It's usually between 30-60 mph under light-moderate acceleration where the car starts vibrating, similar to going over rumble strips like the original post said. It also only does it when the car has warmed up fully, takes usually around 5-10 mins. Thought it a center bearing for the driveshaft, but turns out it's the torque converter. The place I take the car to for any major work said they would want to put in a new trans, but they recommended just learning to live with it as it doesn't make much sense to put in a new tranny in for $6k+ considering what it's worth. There are two things I usually do to minimize the vibrating: either put the trans in sport mode when I start to feel it shuddering, or simply drive it everywhere in manual shift mode. Planning on changing the transmission fluid fairly soon and putting in an additive that may help.
tylerhart_2139.00 |
01-06-2024, 03:00 PM | #19 |
Rep 196
Drives: 2008 Bmw 328i Coupe
Yeah, I would second this. Check the center driveshaft joint and if it’s fine a full transmission service (clean out and new fluid until clean). This is what it stopped it for me. Plus after the transmission feels a lot better.
