      08-16-2022, 02:33 PM   #1
Eileen
Drives: BMW 135 coup
DCT overheating
I have a 2013 135, low, miles (55,560). The DCT temp indicator (picture below) came on amber and immediately switched to red and shut down the engine of my car. I waited a minute, restarted the car and it ran fine. I was not driving the car hard. It was around the town driving.
I took it into a BMW dealer and they claim its a water pump issue. That does not make sense to me as my understanding is the DCT transmission cooling is separate. Can anyone advise me here?
Name:  Screen Shot 2022-08-16 at 10.56.58 AM.png
      08-18-2022, 04:46 PM   #2
TWO STEP TEX
Drives: BMW G30 540i
I believe the trans cooler uses coolant as an exchanger. So they advise replacing the water pump? Have you pulled any codes?
      08-21-2022, 09:26 AM   #3
Helmsman
Helmsman's Avatar
Sweden
5484
Drives: 2011 AW E90 M3 ZCP
Attachment 2958632
Hi Eileen,
interesting input. I have had the DCT heat issue over years and long story short believe I've finally solved by replacing the (aux) water pump which I assume your dealer refer to.
Went to couple of different shops incl main dealer who had no clue and could not comment on my thoughts about the pump. Congrats, you seem to have found a BMW dealer who actually knows its products!
See this thread for further details. Let me know if you can't access the tech desciption ref to and I'll post it separately: https://www.m3post.com/forums/showthread.php?t=1772232
Ps. Posted this reply on the M3Post as well. Reply/post possible questions there as I'm not regular here. https://www.m3post.com/forums/showthread.php?t=1903696
      10-03-2022, 08:54 AM   #4
Snarfnaj
Snarfnaj's Avatar
Drives: BMW m2
Any updates on this? I have the same problem. Dealership wants to toss a whole new dct at it. Inspection report from dealership shows overheating trans. Codes but no cause. Warranty company inspector drove the car and canÂ’t duplicate the problem. Warranty company deems codes not sufficient to have the dct replaced on their dime. 2013 135 64000 miles.
      10-03-2022, 09:26 AM   #5
Snarfnaj
Snarfnaj's Avatar
Drives: BMW m2
      12-08-2023, 07:12 AM   #6
Helmsman
Helmsman's Avatar
Sweden
5484
Snarfnaj, did you get your DCT issues resolved?
      12-08-2023, 07:13 AM   #7
Helmsman
Helmsman's Avatar
Sweden
5484
Attachment 2958632
Eileen, did you get your DCT issues resolved?
      01-19-2025, 02:17 PM   #8
jgbuddy
Drives: N55 DCT 135i
FYI there is no aux. water pump on the e82 dct. If your e82 dct is overheating, you probably have a stuck thermostat in your heat exchanger. The solution is to buy a new heat exchanger, part no. 17217536929 (the thermostat does not have its own part no.) Although the transmission itself is identical, the cooling system is not, and you can see on realOEM that the e82 has no aux pump (Helmsman) .
GoRomeo1829.00
      01-24-2025, 10:25 PM   #9
GoRomeo
GoRomeo's Avatar
Drives: 330i, 135i
2008 BMW 135i  [6.33]
2006 330i  [6.75]
Crazy oveaheatiing issues about these DCT trannys at such as low mileage. I don't think I ve seen these overhearing isues in my ZF transmissions.
