04-10-2024, 12:53 PM | #1 |
Rep 17
Drives: 2013 BMW 135i N55
Error codes 2c58 and 2c86
Hi all. I did an oil change and spark plug change, both OEM, last Thursday and when I started the car it went into limp mode and threw error codes 2c58 and 2c86. I have checked and rechecked the intake and all vacuum lines, as well as replaced the boost solenoid and MAF sensor, but the errors keep coming back. I also checked that the oil filter housing had the middle insert and it does. What else could I check or what could be the issue?
2013 135i N55 with upgraded FMIC, charge pipe and VRSF catless down pipe. I have also been running MHD Stage 2+ for a few years now. |
04-11-2024, 12:57 AM | #2 | |
Rep 3,934
Drives: 330i, 135i
04-11-2024, 02:37 PM | #3 |
Rep 17
Of course. Which is why I noted what items I have checked and parts I’ve replaced.
05-03-2024, 05:32 PM | #4 |
Rep 1
I have the exact same problem right now and I have done the same things as listed by jtriana. Checked for vacuum leaks, replaced the boost solenoid (with the vacuum line that goes to the waste gate), replaced both vanos solenoids (the ones in front of the motor- easy to replace), replaced the MAF but 2c58 error persists. Completely lost at this point. The car is grumpy on cold starts then runs fine once everything is up to temp but the check engine light will not go away.
05-04-2024, 01:42 AM | #5 | |
Rep 3,934
Drives: 330i, 135i
I found this on a quick search How do you fix the code 2C58 on a BMW? The fix will be to replace the oil filter cap if you find the center insert missing. The second item will be to remove the VANOS solenoids and swap them from intake to exhaust. If the fault code changes to an exhaust fault then the solenoid is bad and it should be replaced. |
