05-03-2024, 07:22 PM | #1 |
Rep 2,205
rear hub specs, spline count
anyone have the specs for the rear hubs, i.e. outer cv spline count and shaft diameter?
Any f80 rear hub converts on here? I'm in the middle of a super 8.8 diff install, sourcing rear shafts soon
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten.. 1974 2002, many various 3s. |
05-07-2024, 07:06 AM | #3 |
Rep 2,205
if the hubs interchange with 335i/135i hubs. i.e., same spline count, shaft diameter and width, same bearing size
I thought I saw on a random blog someone converted to them
05-13-2024, 02:44 PM | #4 |
Rep 685
The F80 hub is compatible with the E9x M3 so I don't think it'll work with the E82 axels. They also use M14 wheel hardware instead of M12...
You may want to check out the F8x rear hubs cracking situation, growing concern. |
