      01-26-2025, 04:59 AM   #1
miles 135i
miles 135i 's Avatar
New Zealand
27
Drives: BMW 135i 2010
2010 bmw 135i  [10.00]
  [0.00]
E82 DCT magnetic paddle options
I’ve been doing a little bit of looking around trying to find ones that will fit without an absurd pricetag for the E82 DCT, Have been seeing M3 E9X magnetic paddle Options but I’m wondering if they fit and all the wiring is compatible, same goes for f series and all that, anyone with a DCT e82 had luck with them or know ones that will fit and where to get them?
      01-27-2025, 11:33 AM   #2
MParallel
Mr. OEM
MParallel's Avatar
1046
Not familiar with magnetic paddles.
What is the 'gain' here?
Ok nvm I looked it up. Tactile feel.
IG: iflok
      01-27-2025, 11:47 AM   #3
DWN-N-OUT
DWN-N-OUT's Avatar
37
Drives: BMW 135is, E70 X5D
There was a thread about it but I can't find it now. It can be done but you'll need at least the E9X M3 steering wheel buttons and wiring (PN: 307091785-AB). Those make the paddles plug and play with the E82. Then the issue is the M3 DCT paddles don't fit the cutouts on the back of the E82 DCT wheel, it can be made to work but doesn't fit perfectly flush. If you're OCD about fit and finish like me the best way to go about it is buying an E9X M3 wheel with buttons and then buy the paddles you want. ETA: Part Numbers
2013 135i DCT, FBO+ - Totaled
2013 135is DCT, Pure 750, Motiv Reflex+, ARM Intake, PI Manifold w/ 750cc, ER CP/IC/TIC, PR 2.5 LPFP, Dorch DS25 HPFP, S63 Injectors, B58 Coils, BMW Performance Exhaust, M3 Control Arms, ST XTA Coilovers, Hotchkis Sway Bars, SLG F8x Brake Conversion
2011 X5D - Fisher CAI, Kassel Downpipe, Malone 2.9, fully deleted, BC Racing Coilovers
      01-31-2025, 10:46 PM   #4
miles 135i
New Zealand
27
  [0.00]
My paddles are delayed and don’t like the feel of them
      02-02-2025, 05:49 PM   #5
MParallel
Mr. OEM
MParallel's Avatar
1046
Fitting different paddles won't change the delay.
You may want to look into xHP for that.
IG: iflok
      03-31-2025, 08:00 AM   #6
jasonjoyrides
jasonjoyrides's Avatar
Drives: 2012 BMW 135i DCT
As far as I know, there are literally zero magnetic paddle options for the E82 DCT. It seems that these companies made magnetic paddles for the M3 DCT and then assumed they would work on any other DCT vehicles so they list the E82 as compatible but it's not really. A friend of mine bought a couple different sets that were listed as E82 compatible and they didn't work until he also got the M3 steering wheel buttons. That makes this upgrade even more expensive because the buttons aren't cheap either. I decided to just make my own. I'm getting close to having them finished but had to shelf the project for a bit.
Also, not to jack the thread but on the topic of the shifting delay, if your DCT is not performing the way you'd like it to, I would recommend a full service (fluid and filters) followed by a software update and adaptation reset. A slight bit of performance can be added from xHP, but the snappiness should be pretty good without it.
      04-01-2025, 04:28 PM   #7
eastsidaz
eastsidaz's Avatar
328
Drives: E92 335i
These are decent
https://a.aliexpress.com/_EH4UQgC
But you will need to do the resistor mod as the dct is resistance based shifting. These work ots for ground based steptronic 6AT only. (Please note model 1 in the link above is only for the M3 only)
Resistor mod is here https://www.e90post.com/forums/showpost.php?p=19510582&postcount=4 You dont need the blue end plugs as you can solder into position anyway. But if you can get them it'll be easier.
      04-03-2025, 10:20 AM   #8
MParallel
Mr. OEM
MParallel's Avatar
1046
Most, if not all, of these aftermarket paddles look like something a kid would draw.
I guess I'm the only one that like the original ones. Otherwise you can also swap for the F10 sport wheel thin ones or later M5 silver ones. They all use the same base.
IG: iflok
      04-03-2025, 01:41 PM   #9
zx10guy
Drives: 2013 135i
Too bad Nelson Racing Wheel stopped making the adapters and their own paddles for our cars (and in general).
Here's my thread on installing the Nelson Racing Wheel adapters along with their custom paddles:
https://www.1addicts.com/forums/show...n+racing+wheel
As to the lag, you're probably looking at doing an adaptation reset to get things functioning properly again. I've had to do two on my car so far.
      04-04-2025, 04:27 PM   #10
E82dude1
E82dude1's Avatar
67
Drives: 2011 BMW 135i
Does anyone know if you can remove the stock paddle shifters? I never use them and like the cleaner look without them, would retain M steering wheel just fill in the blanks with some 3d printed plastic pieces or something
      04-21-2025, 09:27 AM   #11
houtan
houtan's Avatar
812
Drives: 2011 135i
2011 135i  [9.85]
I went a different route on getting magnetic paddles to work. I recently got a set of OE F series paddles. Before swapping the modules to my E series paddles, I swapped the connectors over to the F series paddles just to see if they work. To my surprise, they did. The main studs on the back of the F series paddle modules are slightly taller, so I didn’t install them since I had my factory modules, but it gave me the idea to try F series magnetic paddles that should work with some minor massaging.
I ordered this set from aliexpress and they arrived in less than a week: I just found this on AliExpress: $30.51 | Magnetic Carbon Fiber Paddle Shifters For BMW F10 F06 F07 G20 G30 F18 F12 F13 F20 F22 F30 F31 F32 F34 F36 2 3 4 5 6 7 Series
https://a.aliexpress.com/_mNm7on1
I used a file to shorten the main stud. First one took me about 15 min because I was being extra cautious. Second paddle went much faster.
The body of the magnetic paddles is a little more squared off than the original modules so I had to dremel two corners of the plastic mount. Super easy though. After that I swapped my DCT connectors to the magnetic paddles and everything works.
The wires on the f series paddles are a lot shorter than e series, so I thought I would have to lengthen them. But it turns out they are the perfect length.
Pictures below:
javinci54.50
      04-26-2025, 09:24 AM   #12
MParallel
Mr. OEM
MParallel's Avatar
1046
Nice job.
houtan812.00
      11-26-2025, 11:35 AM   #13
N55 Nate
N55 Nate's Avatar
2012 BMW 135i  [0.00]
Pictures below:
How did you go about swapping the connectors?
