08-27-2008, 09:00 AM | #1 |
Unindicted co-conspirator
67
Rep 1,734
Drives: to work, mostly.
Timing Belt
Is there a timing belt in either the N52 or N54 engines? If so, what is the recommended service interval? Thanks.
08-27-2008, 10:43 AM | #4 |
Rep 1,609
Timing chain supposed to last for a very long time and does not required periodic replacement or service until it start slipping.
08-27-2008, 11:18 AM | #6 | |
Rep 149
...I replace the timing chain at the 100,000 mile mark...
NetEagle
'11 335i Le Mans Blue, Saddle, Dark Glacier, Manual, M-Sport, Premium, CA, Harman Kardon, Heated Seats, iPod, High Beam assist, 35% tint, Stone-X, BMW Performance Exhaust, Shadow Grill, CF competition spoiler |
08-27-2008, 11:38 AM | #8 |
Rep 628
How could a chain slip? I imagine it's something like a bicycle chain, right? A bicycle chain has to be pretty worn before it slips, nothing like the notched belt in many cars.
Waiting on a 2015 M235
08-27-2008, 11:52 AM | #9 |
Rep 149
Over time, the chain will stretch, when that happens, the teeth will begin to wear, and before you know it, the stretched chain will slip over worn teeth...ka boom
NetEagle
08-27-2008, 12:50 PM | #10 |
Rep 628
The owners manual that came with the car doesn't say anything about regular maintenance on the chain. What are we supposed to do?
My TTs manual said to change the timing belt every 115,000 miles I think.
08-27-2008, 01:31 PM | #11 |
Rep 404
To continue the bicycle analogy, with a bike you measure the chain and when it starts to show wear, by increased length, you change it to keep it from wearing down the teeth in the front chainring and rear gear cluster.
08-27-2008, 06:12 PM | #12 |
Rep 828
I think there is a chain tensioner which is spring loaded to keep tension on the chain. Years ago I rebuilt and tuned MG engines and that is how MG did it.
It’s the timing belts that need to be replaced at 100K miles, chains last forever. Also, if you do not have a zero clearance engine and the timing chain slips the engine should not be harmed. If you have a zero clearance engine and the timing belt/chain slips the pistons hit the valves and ruin the engine.
2019 X3 M40i - Black Sapphire Metallic - Mocha Lather - 21" 718M wheels - Every option except Sun Shade
08-28-2008, 11:36 AM | #13 |
Rep 1,396
So does anyone know if either of these engines are "zero clearance engines"?
08-28-2008, 11:44 AM | #14 |
Rep 2,205
isn't everything zero clearance now?
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten.. 1974 2002, many various 3s. |
08-29-2008, 09:16 PM | #16 |
Santa Fe Concorso
107
Rep 2,984
Yes, they are both zero clearance. Many past BMW owners have found this out by the dreaded "mis-shift" downshift that over-rev'ed the engine, floats the valves, and said valves impact the piston tops. Nasty (and very expensive) business.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
