05-18-2010, 10:59 PM | #1 |
AutoXer
36
Rep 683
Battery replacement
The latest Bimmer magazine says you have to take the car to the dealer to replace the battery since it has to be electronically registered to the car. 1.1 hour charge they say. I've not heard of this before. Anyone know if this is true, or can us DIY'ers just replace the battery at home?
05-19-2010, 12:31 AM | #2 | |
448
Rep 2,373
Every time you replace the battery, you need to register it with your car. You can take it to the dealer, or find an Autologic shop who can program it for you. |
05-19-2010, 05:11 AM | #3 |
Rep 22,992
Some people here have said that as long as you replace the battery with the same cold cranking amperage... you will be fine. So they say.
Or... replace the battery and reset the ECU with a BT scan tool. Or... go to the dealer and PAY! |
05-19-2010, 08:46 AM | #4 |
Rep 3,550
I found the attached interesting. Apparently the logic for charging the battery is fairly sophisitcated in our bimmers and it needs to know when you put in a new battery so it charges it appropriately. It matters if it is AGM - some sort of mat instead of just water/acid - or conventional water/acid (which is basically not recommended since it gives off more gas and the battery is inside the car). It also matters if it is old or new and I'm sure the size matters too. The article describes the process.
"Registering" is basically telling the charging logic that the battery is new and a little information on the battery. The penalty for not "registering" is potentially shortened battery life. You need a better OBD-II interface than I have but people other than a dealer should have it. Jim
05-19-2010, 11:57 AM | #6 | |
Rep 1,423
Drives: M-Sport 128i, 328xi, 3.0CS
Even the trickle charger needs to know which type of battery you have. There are two available from BMW; one for regular wet cell lead acid batteries and one for the newer AGM batteries.
'09 128i - Black Sapphire Metallic\Coral Red\Glacier Silver\N51 DISA\6MT\Navigation\Premium\M-Sport\Heated seats\Xenon\Headlights\iPod\Smartphone\Euro Delivery
05-19-2010, 12:04 PM | #7 |
Rep 524
im trying to figure out if im using the right charger for this battery. i dont want to do more harm than good. all of the lights seem to indicate that its working properly.
i posted this last night. the pic says programmed for gel batteries, but mine doesnt have that sticker. I purchased it 2 years ago for my aging e36, with new battery.
2009 135i Coupe - Sedona Red Metallic - Savanna Beige - 6MT- ///M Sports Package - Boston Leather - Power/Heated Seats
2005 BMW F650 GS - Mandarin Yellow - Farkled |
05-19-2010, 12:16 PM | #8 |
Rep 3,550
I would not worry about using whatever battery charger you have to get a battery to usefull condition. I don't think you can do much damage charging a battery once even if the charger is not ideal for your battery. The question is more if you can really do any damage if you charge it every single time over a period of months or years somewhat wrong for that battery, how much damage can you do.
I have two battery chargers. The one I usually use has a 6 and 12 volt switch, 10A and 2A switch and a switch for deep cells or normal. Nothing for AGM or gell cells. If I ever need to use this charger on my bimmer, I will. And if I ever get a gel cell for anything, I would use it for that too. I do try to get the 6 versus 12 volt switch in the right position, however. Jim
05-19-2010, 09:55 PM | #9 |
AutoXer
36
Rep 683
JimD, thanks for the PDF, that's what I was looking for. Sounds like no issue to replace the battery at home, but once you do, you need to have it registered soon after. Hopefully there will be a way to do this at home before my '09 needs the battery replaced. At least I don't have to go to the dealer to replace it.
02-12-2014, 10:29 AM | #10 |
Rep 3
Battery Frustration
I was trying to be proactive, and replace the battery on my 09 135i convertible before I got stranded. Dealer quoted me $635 including reprogramming! Yippeedoo~he will put me in a free loaner lol! Advance auto will install one with 700+ cca for $160, but doesn't know a thing about reprogramming,and from what I've read that will mess up my alternator. I think I will put in an order for a 235, lease it w scheduled maintenance and warranty, and hope the battery lasts that long.
02-12-2014, 11:31 AM | #11 | |
Rep 1,026
02-12-2014, 11:43 AM | #12 |
Rep 3,550
This is the cable that I use and others use for coding:
http://www.one-stop-electronics.com/...&product_id=16 It's $99 and has a serial to digital converter built in. There are lots of comments on coding forums from people wanting to know if a cheaper cable will work. Some probably do. But there are also comments from people who bought a cheaper cable and had to buy another because the first one didn't work. Registering is a one or two step process depending on whether the replacement battery is the same size and type. If it is, one step. If not, then you also have to tell the car about the battery and that's an additional step in a different piece of software. I haven't done a battery yet but the coding I've done wasn't hard but it can be frustrating when something doesn't work and you don't know why. If nothing goes wrong, it only takes a few minutes. I've seen comments about people coding remotely.
02-12-2014, 10:06 PM | #13 |
AutoXer
36
Rep 683
Has anyone tried this:
http://www.autoenginuity.com/product.../bmw-sr01.html Seems like a good deal for the price, both service reset and battery registration
02-12-2014, 10:49 PM | #14 | |
bimmerphile, technogeek
1005
Rep 3,792
Drives: 2012 E82 6MT Sport
02-13-2014, 07:49 AM | #15 |
Rep 3,550
I'd love to see feedback but my guess is this could "register" the new battery of the same type and size but not reprogram the car for a different size or type of battery. The reason I say that is the register operation is a one command thing. The reprogramming operation is done either by changing the vehicle order or changing a line in a part of the car's program by downloading the entire program area into a laptop, changing a line, and then uploading the program. The change is a function of the new battery.
02-13-2014, 08:20 AM | #16 | |
1005
Rep 3,792
02-13-2014, 11:44 PM | #17 | |
Rep 1,491
Black Wrapped Roof, BFG Rivals, Dinan Camber plates, M3 Steering wheel, Matte Black kidney Grills, H&R Sport springs,
Sparco assetto gara,Pagid sport Brakepads,STOPTECH Slotted Rotors, DISA STG3,EURO BOX |
12-19-2014, 11:06 AM | #18 |
Rep 67
Despite my preference for the economical battery replacements of the 1970's through 1990's (e.g., Sears Die Hard), I do recognize that the E82 I'm now driving is a mechnical system operated largely by a computer (DME) that has many hundreds - or thousands - of parameters.
The battery replacement cost is absolutely a sting compared to "the good old days," but then again I wasn't driving 130MPH on a track "back in the good old days." Definitely I won't be looking for workarounds to BMW engineering. I have to trust that they designed and spec'ed the battery in exactly the way they did for sound engineering reasons and with the entire mechanical and electrical/electronic system in mind (what the heck else would they have done?). So, ya know, I'll suck it up and pay what's needed to have this major component replaced correctly and according to spec rather than to second-guess BMW engineering. Kinda think that bootstrapping a "cheap" battery and half-guessing the correct DME coding for it is a bit shortsighted. But that's just me.
2011 135i 6MT, Cobb FMIC, Stoptech ST-60, Pagid RS-29, Castrol SRF, Goodridge G-Stop, Apex EC-7, Dinan Front Sway, Ohlins R&T, Swift 400/500, Vorshlag Camber, M3 lowers & bits, Diffsonline 3.08 3-clutch, Sparco Ergo/Evo, Schroth Hybrid, RRT welded 4-point hoop
DD: BMW 328xiT Prior: 2000 323iT 5MT, 2000 Z3 2.3 5MT, 2001 325iT 5MT, 2009 128i 6MT |
12-20-2014, 02:55 AM | #19 |
Rep 625
Drives: '09 E88 135i M-Sport/6MT/SGM
Should I be worried, I checked on my P3 gauge before I start my car and my battery is sitting anywhere from 11.7 to 12 volts on cold starts? I think I read somewhere it should be at 13. When my engine is running its around 14.7. Thanks
| Dinan S2=>MHD | e46 M3 trans mounts | Dinan CF CAI | ER CP | HKS SSQV4 BOV | RB PCV Valve | VRSF DP | N55 MP | BMW PE | OC | VRSF 7" FMIC | UUC Evo3 SSK | EBC GD Sport Rotors | EBC Redstuff | TRW F+R | | Whiteline KDT918 | H&R Front Sway | BMWP 313 | MPSS 225/255 | Scopione CF Rear Diffuser | iCarbon CF Rear Spoiler | P3 v2.1 Gauge | Interior LED Retrofit |
12-20-2014, 09:54 AM | #20 |
Rep 376
just get the bmwhat app and register the battery yourself. it's a $50 app but you can do tons of stuff with it from diagnostics to coding on/off features in your vehicle.
05-01-2015, 08:27 PM | #21 |
Rep 2,205
I run a ctek on my OEM 2008 battery every few months, hoping oem lasts me another 5 years
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten.. 1974 2002, many various 3s. |
05-02-2015, 11:44 AM | #22 |
Rep 43
What kind of batteries are you guys replacing the OEM with? Mine is on its way out and after some playing around with BMWhat apparently my original is an 80Ah (140RC) non-AGM. Thinking of going with an AGM especially since BMWhat can program and register it for a fraction of what the stealership will charge!!
