      06-01-2012, 09:37 PM   #1
Sam@Alekshop
Sam@Alekshop's Avatar
Drives: BMW M3
✪ Alekshop ⎢Now Offering Corner Weight Balancing in House
Now your car can be balanced, corner weighted and aligned in one place.
Setting the car properly for the street or for the track is not an easy task. Surely it becomes easy if you have the right equipment and knowledgeable stuff. We have both!
With the change in the geometry of the suspension when lowering the car, it’s crucial to maintain the right ride height and perfect weight distribution. In order to achieve that, it requires more than just to align the car and tell the customer your car is done. The proper way to do that, is to place your car on the scales and measure each corner to see how the car is balanced. Of course prior to that, we ensure that the ride height is set to be the same on all four corners so we can get our base line readings. Once you get that out of the way, now you can play with the suspension and adjust each corner to achieve the perfect balance.
Post in here http://www.m3post.com/forums/forumdisplay.php?f=151
      06-01-2012, 10:55 PM   #2
Grayson
Heisenberg
Grayson's Avatar
51
Drives: 2008 135i
Those FI's make me hot.
AR Catless Downpipes | Berk Full Street Exhaust | HPF FMIC | COBB AP | aFe Magnum Stage 2 | E93 M3 Front Sway Bar & Bushings | Michelin Pilot Super Sports | Hardwired Radar | Eurotek BBS LM | Schmiedmann LCI Blacklines | BMW Performance: Spoiler, Diffuser, Shift Boot, E-Brake
      06-05-2012, 10:13 AM   #3
Alekshop
Alekshop's Avatar
Drives: E30 M3 l E46 M3 l GT4 l 991 RS
      06-13-2012, 10:53 AM   #4
Alekshop
Alekshop's Avatar
Here is a 335D being CW balanced after the installation of KW V3 with Vorshlag CP
