10-03-2013, 12:54 AM | #1 |
Rep 1,054
Quad options?
I'm quite a fan of this 1M replica rear bumper for the 135i. Always loved the rear end of the 1M.
http://www.kerscher-tuning.de/stylin...lang=en&id=754 In addition to this, I've always wanted a quad exhaust. Kersher in these pictures are using a Bastuck exhaust with 85mm tips and I think it looks really nice. I've been advised any 135i quad exhaust work. Anyone here with quad experience that could share their experiences with the forum? Cheers! |
10-03-2013, 04:23 PM | #4 |
168
Rep 1,460
Quad exhaust JAPAN
Had a 135 in for service yesterday that had an interesting exhaust fitted,
one that I have not seen before made in Japan by ARQRAY. This is the best quad system I have seen, the workmanship is outstanding with a perfect fit. total work or art |
10-03-2013, 05:44 PM | #5 | |
Rep 1,054
Remus sounds nice, but I don't like the look of the pipes or the tips unfortunately. Side pipe - 3D Design / ARQRAY Diverted pipe - 3D Design / ARQRAY Eisenmann Quad - Not a fan of how flimsy the side pipe looks on this. REMUS - Sounds nice but just not a fan of it visually Last edited by PeteA; 10-03-2013 at 11:45 PM.. |
10-03-2013, 10:28 PM | #6 |
Rep 680
yeah i always thought the remus looked pretty dodge in that picture but they've had very positive feedback in real world applications. I don't know if you can call that eisenmann setup a true quad :P that pipes so skinny you may as well just glue fake tips on the right. really like arquay round the back though! how much is it?
10-03-2013, 10:48 PM | #7 | ||
Rep 1,054
10-03-2013, 11:36 PM | #8 | |
Rep 2,682
10-04-2013, 06:08 AM | #10 |
Rep 1,515
10-05-2013, 12:51 AM | #11 |
Rep 1,054
A few more pics of the ARQRAY from the WSTO 135i way back
http://www.1addicts.com/forums/showthread.php?t=510186 |
10-05-2013, 07:55 PM | #12 |
Rep 1,054
Just a quick update this lazy Sunday.
Bastuck and ARQRAY are almost identical in design. Bastuck is made in Germany, ARQRAY is made in Japan. The ARQRAY is looking to be north of 2.5k. For an axle back that's pretty expensive but its pretty darn sexy looking. I'll inquire about the Bastuck as well then post back. http://www.bastuck.de/shop/index.php...11020&detail=1 |
10-05-2013, 08:33 PM | #13 | |
Rep 1,515
Off track but anyone know what's up with BMR's website? has been down for a few days now at least. |
10-05-2013, 09:29 PM | #14 | |
Rep 1,054
I agree with you, it sure is expensive for an axle back, hence I'm going to inquire about the Bastuck too as its an almost identical design.
An alternative to consider is the Kersher 1M replica rear over another diffuser / stock bumper combination (for something different). I think it looks great. http://www.kerscher-tuning.de/downlo...her_e82e88.pdf Official word from Kerscher. Quote:
10-07-2013, 12:03 AM | #15 |
Rep 1,054
Ok,
Here is my reasoning on why the ARQRAY with its 3D Design quad carbon fiber diffuser is the best go-to bolt on solution for the 135i. Top three 1st ARQRAY - ~76cm tips spacing. Diverted pipes, unvalved ~$2.5k Why you shouldn't - Price. Some small trimming required of the underskrit next to battery. Why you should - Looks great, perfect fitment, cheaper of the two ARQRAY systems. Bolt-on solution. 2nd Eisenmann - ~76cm tips spacing. Why you shouldn't bother - The side pipe is flimsy and is not a true quad. About the same price as the ARQRAY (>2K). Why you should - Easy to get in Australia. Looks good and quality seems top notch. Compatible with 3D Design quad diffuser. Bolt-on solution 3rd ARQRAY - ~76cm tips spacing. Side pipes, valved ~$4k Why you shouldn't - PRICE! Why you should - Absolutely no trimming required compared to other system. Bolt-on solution. Honorable mention: - SuperSprint - 58cm tips spacing Why you shouldn't - Requires BMW 1M rear conversion. The Kerscher 1M rear bumper at the beginning of this post is spaced at 76mm apart so is incompatible. Given the price of their other products, this will cost an arm and a leg. Why you should - You're planning a 1M rear end conversion and don't want to do the full battery tray / leads etc change too. Other stuff; - Remus - Looks like crap. Pass. - HARTGE - Not sure on the tip spacing. Fairly sure it required the HARTE valence as well (which I think looks overdone). - BASTUCK - If you google search some fittment pictures you will see that the tips sit about 15 cm too low and required their own specific valence which looks horrible. Given this, I'd avoid the Kerscher 1M replica rear end as well as they are using the BASTUCK exhaust on the pictures on the OP and this risks of not working with all the other stuff should you decide to use those exhausts instead. Have fun guys. EDIT - The only alternative is a full conversion ala Stu @ BMR http://www.1addicts.com/forums/showthread.php?t=818172 Last edited by PeteA; 10-07-2013 at 01:55 AM.. |
10-07-2013, 04:35 AM | #16 | |
Rep 680
http://www.1addicts.com/forums/showthread.php?t=492082 |
10-07-2013, 04:58 AM | #17 |
Rep 1,054
Wasn't aware of that one. Looks like a pretty good design (simple infact). I'd probably have put that one in at third place, especially for value for money. Not sure if you can get that axle back only as the custom midpipes might induce a drone over the N55 midpipes.
Listened to a few videos on youtube (i know it probably wouldnt compare to in person) but it seems to be lacking the nice straight 6 sound that the likes of the BMW Performance exhaust brings out. This is a personal taste thing, but I think the ARQRAY sounds the best out of the lot of em. http://www.esstuning.com/products/13...st-System.html |
10-07-2013, 05:15 AM | #18 | |
Rep 3,099
and for these $2500 prices... it's so deep into extremely personalized custom-muffler money.. i mean, you could go to any high-end exhaust shop with this budget and get something absolutely amazing, out of any material whatsoever... heck, probably custom downpipes included for the pric.e.. |
10-07-2013, 05:26 AM | #19 |
Rep 1,054
Battery convertion will cost you 1.2k ish? Excluding diffuser (this is a constant between ehxuasts lets say) and exhaust ontop (minimum 1.5k?). In addition, any 1M exhaust you put on will require cutting to fit to the right spacing....do you really want to cut an akra? You may be able to find or custom make a 135i quad diffuser that has 56cm tip spacing.
Might be able to pick up an OEM 1M exhaust cheap as chips, but Id assume you're after a bit more oomf than a stock exhaust. Pros/Cons I guess flinch I personally prefer a simple bolt on solution. Last edited by PeteA; 10-07-2013 at 05:39 AM.. |
10-07-2013, 05:31 AM | #20 | |
Rep 1,054
On the flip side, many have spent 6-7k on an evolution system with good reason. (fittment, warranty, worksmanship, harmonics, materials, visual appeal ++++ any other RnD involved in making an exhaust). |
10-07-2013, 04:17 PM | #21 | ||
Rep 3,099
most of the pricings, if i remember right, seen are around the $500-$600 mark in parts i think (DIY) (assuming you don't custom make your own battery post+cables which saves boatloads) and the $1.2k figure includes a nice diffuser + 1M muffler... though yes, i agree you'd probably be after something with a bit more throat, and the price would probably end up quite a lot closer to the $2.5k figure anyway... point.. haha can understand wanting a direct bolt on, but $2.5k is a ton of change for what is, realistically, purely for looks? Quote:
strangely, i can almost totally agree with and understand the decision to go with an evolution... if you have that kinda money, it's probably the better choice all over lol... besides the fact you're guaranteed to get that sound. mmmmm. one day... haha |
10-07-2013, 10:38 PM | #22 |
Rep 1,515
Froop has just advertised an oem 1M exhaust for $400. http://www.1addicts.com/forums/showp...postcount=4086 i didn't realise though until reading above that it sound's like quite a pain to fit to 135.
