08-15-2019, 09:48 AM | #1 |
Rep 66
Help with rear suspension rattle please
Sorry for the "omg rattle" post, but this one has me stumped.
Guys, I noticed a new rattle. Not sure how long it's been there. Only new thing done to the car was Costco tire plugged a nail in the driver rear tire. Sound is only driver side REAR, only going over bumps - quick/sharp bumps (not like rolling over a speed bump). Think more like road divots, small pot holes, cracks, seams in parking garages (this is where I noticed it). Sounds like metal on metal (almost like a shroud smacking a control arm). Can't figure it out. Thoughts? I doubted it's the shock mount, as I don't ever hear it in the car. Only when window is down. Last edited by SolidWater; 08-16-2019 at 05:27 PM.. |
08-15-2019, 10:09 AM | #2 |
1Addict
3233
Rep 7,893
Sway bar end link if in the absence of any other problems
08-15-2019, 03:58 PM | #4 |
Rep 66
Good thoughts I'll check that out. I doubt it's the shock. There's no change in how the car rides.
I don't see any fluids or residues. I did get to drive by a median so I could hear it better it sounds a little bit more plastic like...not even sure what's back there that could rattle like this. It's definitely not the exhaust and I don't think it's any of the exhaust mounts. |
08-16-2019, 05:13 PM | #9 |
Rep 66
Here's the sound...
This is only on the driver side rear. Sorry for wind noise, etc. It's the very clicky sound. http://player.vimeo.com/video/354306603 Last edited by SolidWater; 08-16-2019 at 06:30 PM.. |
08-19-2019, 09:17 AM | #11 |
Rep 171
Hard to tell from the video, but they may have bent the brake dust shield when pulling the wheel off and putting it back on. The shield can get bent pretty easily. If it's bent where it's barely touching, then you'll get a rattle. Pull the wheel, bent the shield out a little and make sure there's a slight gap between it and the rest of the parts so it's not touching. Doesn't hurt to at least try that out.
-Sam |
08-23-2019, 09:13 AM | #12 |
Rep 66
Checked the brake shroud and no dice. Doesn't seem to be that. Definitely more a rattle than a click/clank... any other ideas? Driving me nuts and I don't want to take it to the nearby dealers cuz they'll easily find things to replace/repair at my cost...
08-25-2019, 08:10 PM | #16 |
Rep 66
Solution? I think I found it.
So I took off the rear wheel. Nothing seemed loose. Checked all nuts/bolts for proper torque. Literally banged on everything with a rubber mallet. ...And heard the rattle. Pictured below. It's something on the brake pad apparently. Not sure if it's broken or what. This: View post on imgur.com It's loose and rattling unlike the others. I presume it's part of the interior brake pad? https://3a663eb0fef48c6d2d60-a88f8eb...2536_x800.webp Doesn't seem to effect anything, other than the sound. I padded it with a piece of cardboard to check if it's the culprit and sure enough the sound went away. Should I replace the rear brake pads or is it just a symptom of something loose? Couldn't tell if there's a loose bolt/tensioner back there... |
08-26-2019, 10:55 AM | #17 |
Rep 2,232
I believe that's just a weight to help with the harmonics of the pads I believe. You should be able to remove the pad from the top of the caliper and hit it with a punch to peen over the rivet a little tightening the weight.
08-26-2019, 03:04 PM | #18 | |
Rep 66
View post on imgur.com |
09-10-2019, 12:01 PM | #19 |
Rep 66
Solution:
My rear pads are power stops. The above image shows what was rattling. Confirmed (and temporarily solved) by ziptying it against itself. I took it out and tried to figure out why it came loose but it's not evident (unless it's glued there). I didn't have anything appropriate to glue. So far the small zip tie is holding it in place until i replace pads. |
09-16-2019, 02:09 PM | #20 | |
Rep 171
-Sam |
