      04-06-2015, 10:50 PM   #1
kobeballer96
kobeballer96's Avatar
Drives: 6SPD E82
Service engine soon.
help this weekend I was driving home from North carolina to Maryland for the weekend to see family. I got the service engine light around 200 miles into my trip. Being annoyed of the light I got off the highway to a gas station to see what was up. My RPMs seem as the like to hang when i rev then finally drop. At idle it would fluctuate from 500 to 800 then come back to a normal idle after the car settled. Car only has 37k miles on it. I don't think it's coils or plugs maybe a O2 sensor? The light went away after I parked the car on Thursday night and hasn't came on since. Today I felt as the car wanted to bring the light back on again going home today, it was showing the symptoms from the last time the light came on but I stopped to let the car cool off and get gas. I can't read any codes since the light isn't on anymore. My n52 is a 2009.
Black Wrapped Roof, BFG Rivals, Dinan Camber plates, M3 Steering wheel, Matte Black kidney Grills, H&R Sport springs,
Sparco assetto gara,Pagid sport Brakepads,STOPTECH Slotted Rotors,
DISA STG3,EURO BOX
      04-07-2015, 12:41 AM   #2
inline sex
inline sex's Avatar
Drives: SGM 135I 6MT
Get it checked out. Past and pending codes will still come up.
      04-07-2015, 07:35 AM   #3
hoki06
hoki06's Avatar
229
Drives: 2010 BMW 128i
Codes are stored even if the light goes out. Take it somewhere and get it hooked up to a diagnostic scanner like Autologic and see exactly what's going on.
      04-07-2015, 11:26 AM   #4
kobeballer96
Drives: 6SPD E82
Code came back as p0015 okay now what, it says something about timing.
      04-07-2015, 11:52 AM   #5
kobeballer96
Drives: 6SPD E82
It's my vanos solenoid i believe .
      04-07-2015, 12:00 PM   #6
hoki06
hoki06's Avatar
229
What did you use to pull that code? If you get it hooked up to a proper diagnostic system it will give you much more detailed info as to what exact sensor is the issue, not just a generic P code.
      04-07-2015, 12:37 PM   #7
kobeballer96
Drives: 6SPD E82
      04-07-2015, 12:38 PM   #8
kobeballer96
Drives: 6SPD E82
Here Ya go. I did some research but haven't exactly narrow it down.
      04-07-2015, 05:06 PM   #9
JimD
JimD's Avatar
368
Drives: 128i convertible
Here's a thread that involves the same code. In his case it was the Vanos seals:
http://www.bimmerfest.com/forums/sho...d.php?t=427473
I use Torque to read OBDII codes. You can do it while driving (if you have the OBD to Bluetooth plugged in). I also have an inexpensive reader.
      04-08-2015, 07:42 AM   #10
hoki06
hoki06's Avatar
229
The reason I'm saying use a shop with the fancy scanner is because I had similar symptoms as you and eventually got a similar code using Torque. I starting researching how to replace the cam position sensor because the P code was pushing me toward that being the issue. Using the Autologic scanner at my local indie shop they got a different type of code with detailed description saying it was the VANOS exhaust solenoid. Replaced that and it's been perfect ever since.
BMWs shouldn't be diagnosed with P codes. If you use the proper scan tool, there are more detailed codes that point to the exact problem.
