06-29-2016, 08:14 PM | #1 |
Rep 2
Rear Seal Leak
Hi All,
Long time lurker, first time poster. I've tried searching for the past hour or so and haven't had luck finding the answers I'm looking for. I bought a 2009 135i MT with 65k miles about 3 months ago. I took it to an indy for a PPI, and they came back with a few things, nothing enough to deter purchase. I brought it back to them to replace the leaking OFHG seal, as well as do a walnut shell blast. They also put some dye in the oil to see if there were any additional leaks. About 6 weeks go by and I bring it back to the indy to mount some new tires and check the oil dyes. Prior to replacing the OFHG I did notice some oil on the ground, but haven't seen any since, so I wasn't expecting anything to come from the oil dyes. Lo and behold, the indy calls me up and not only do I have a rear seal leak, it's a 10 hour repair and it will run me $1300. Searching hasn't come back with many hits, so I can't get a good feel for this, and I would really appreciate it if you guys could help me answer these questions: - I saw a post on N54tech say they got an estimate of $650...don't know their location, but I'm in the Chicago suburbs. Is 10 hrs/$1300 a reasonable time/price estimate? - I've seen lots about oil leaking from the OFHG and the Valve Cover, but almost nothing on this. How common is a leaking rear seal on the N54? - I'm ok with a wrench, but don't have the time/space/tools to tackle something like this on my own. My indy said it's 'leaking a fair amount', but I haven't seen anything on the garage floor, or had to add any oil. How urgent is this repair? Thank you, Greg |
06-30-2016, 12:03 AM | #2 |
Thread killer
643
Rep 1,896
07-12-2016, 04:35 PM | #3 |
Rep 119
I'm at 68k and my mechanic noticed mine was leaking as well. He adviced me when I was ready for the service to replace the flywheel and transmission as well since they have to drop the transmission. You might want to look into that as well so you can save some money on labor in the future.
07-12-2016, 07:42 PM | #4 |
Rep 3,323
Mine leaked last year and ruined my clutch. I was lucky BMW went 50/50 with me on the repair since I was out of warranty.
07-12-2016, 08:03 PM | #5 |
Rep 22,992
If its not leaking that badly... I would wait. Your gonna need to replace the clutch when you do this job. Or you will be back there again(sooner rather than later). You might also want to replace the flywheel or at least resurface it - when you do this job.
A rear crankshaft seal seems to be kind of common. Especially on 1M's for some reason. Also this bad seal can cause some weird fluttering noises when the AC is on and the revs fall from 2,500 to 1,700 rpms. good luck, Dackel
07-13-2016, 08:05 PM | #6 |
Rep 493
mine has a small leak as well. Since I am at 150k i know that my clutch will be done by the end of the summer, figure I will get it done then.
Tags |
oil leak, rear seal |
