09-16-2014, 08:21 AM | #1 |
Rep 61
Opinion on changing coolant
I planned to flush out the old coolant which I did that 3 years ago. I brought it up to the dealer upon the service schedule. However, the representative told me to leave it untouched if it is fine so far.
I have hesitation on his suggestion. Therefore, I would like to seek a second opinion in this forum. Does it really harm the system if I refresh the coolant. Thank you! |
09-16-2014, 12:46 PM | #4 |
Rep 65
Since the water pumps seem to have a problem with only lasting 4 years / 50k miles, seems like you could get by only changing the coolant when you do the pump - assuming that the coolant still "looks" good...
09-16-2014, 06:56 PM | #5 |
Rep 1,714
Drives: 2011 335i
Just remove the lower hose that goes to the water pump and remove the petcock from the radiator. Refill with 50/50 mix perform the bleeding procedure and your done.
09-16-2014, 07:42 PM | #6 |
Rep 229
Drives: 135i.N55.6SPD.M-SPORT
Hahah I laughed. (I also just replaced my water pump at 48k miles)
TauK-n Tky 1. at a time///
09-16-2014, 08:14 PM | #7 |
Rep 722
Change all fluids in half the time or less than what BMW insist. Lifetime fluids are supposably 100k fluids but i have changed or flushed them sooner as i plan to with transmission very soon.
11' m57 335d 165k Miles - JR 2, ATM Full Exhaust & Intake, Wagner FMIC, AAR Boost Pipe, AAR Swirl Delete, AAR EGR Delete
08' n54 135i FBO E85 - SOLD |
09-17-2014, 08:57 AM | #10 | |
Rep 65
I do agree that it makes sense to do the transmission sometime before 100k miles. |
09-17-2014, 09:43 AM | #11 |
Rep 952
Color of the coolant isn't exactly the way to judge it.. Yes, it can look bad with age but the chemicals still degrade over time while retaining a blueish color.
09-17-2014, 11:43 AM | #12 | |
Rep 722
Im getting some rough shifts at times that is likely due to dirty tranny fluid
09-17-2014, 11:45 AM | #13 |
Rep 722
i believe the pan and oil come out to about the $200 range
09-17-2014, 11:54 AM | #14 | |
Rep 22,992
You can buy the ZF trans fluid and filter kits here... http://www.thectsc.com/index.php?p=home
09-17-2014, 12:25 PM | #15 | |
Rep 722
