12-01-2023, 07:41 PM | #1 |
Rep 231
Taillights woes
So I found out that my right taillight running light isn't working. Just the running light does not work. Turn signal, backup, and brake light, all work fine.
What could be simpler than changing a lightbulb? Here's a part finder of the tail light: [IMG]Tailight by dgua, on Flickr[/IMG] This isn't very clear, but my guess is: 05: running light P21W 06: turning light PY21W 07: brake light H21W 08: reverse light 16W “921” So I order new P21W light bulbs. Tonight I take apart the tail light: [IMG]IMG_3155 by dgua, on Flickr[/IMG] And replace bulb #05 (upper right in the pic). But nothing. Running light still does not work. Then I rotated bulb #07 180 degrees, but still nothing. What's the next step?? |
12-01-2023, 08:41 PM | #2 |
Rep 3,350
5 is outer brake light, in the separate socket.
6 is the inner brake light 7 is the turn signal 8 is reverse light Tail/running light is an LED, not a bulb in a socket. Check the manual, there is a good description with diagram. |
cerealwars78.00 |
12-01-2023, 09:15 PM | #3 |
Rep 3,854
Drives: 330i, 135i
I had similiar issue with my left side taillight and remember and from the diagram I twisted the #5 bulb socket few times and thats how I got the LED running light to work. Try that see if it helps.
cerealwars78.00 |
12-02-2023, 04:07 AM | #4 |
Rep 3,350
Tha manual also mentions that the outer brake light socket must be fully seated or else the LED running light may not work. It has one of those exclamation points notation, which means to pay special attention.
cerealwars78.00 |
12-02-2023, 10:56 AM | #5 |
Rep 3,854
Drives: 330i, 135i
There you go. Yeah I noticed that when I replaced the bulb in that socket.
12-02-2023, 01:41 PM | #6 |
Rep 231
Ok, after a bit more experimenting. Here's a better pic, that shows the location of the lightbulbs as they sit in the taillight:
[IMG]IMG_3156 by dgua, on Flickr[/IMG] Lester got it almost right. At first, I didn't realize there's another lamp, the "outside brake lamp" in a separate socket. That one works Ok. All the lamp functions are indicated in the pic. Except the upper left (07 presumably), which I could not get to turn on while idling. (I didn't know we have a "brake force" lamp. Does it really work? How?) At any rate, the LED running light still does not work. I have re-seated all the bulbs, including the one in the outer socket. Does that mean that I have to replace the whole tail light? It's $190 online (OEM), and RockAuto has one form Hella for $130. Kind of strange that the LED would fail before the lightbulbs. |
12-02-2023, 06:26 PM | #7 |
Rep 3,350
The brake force light is an extra light that turns on when panic stopping in North America. If you have the European light switch, then it acts as the rear fog light you can activate it with the rear fog light switch.
Blau366.50 |
12-03-2023, 07:45 AM | #8 |
Wolfsburg to Munich
75
Rep 294
Just went through this too with my drivers side. The LED board for the running light is usually to blame. There are some online dyi repair procedures where you have to cut into the fixture to get it out. For 120 or so I replaced it. Make sure was others have mentioned that the bulb socket furthest up and outboard is properly seated. This socket powers the led board and could be the problem.
12-03-2023, 12:37 PM | #9 |
Rep 231
Converted1 Thanks for the hint.
Here's the video about board-level repair (even though it's for an E92, it looks very similar): https://youtu.be/miNY9_GJ9aY?si=h11l386qkbmiXkT7 Also, there are several sources of a similar PCB for X3, where this problem seems to be even more common. I am now resigned to replace the whole tail light. Any opinions on OEM vs. the one from Hella? |
12-04-2023, 12:39 AM | #11 | |
Rep 3,854
Drives: 330i, 135i
12-04-2023, 04:36 PM | #12 |
Wolfsburg to Munich
75
Rep 294
I actually prefer pre LCI look and replaced the bad drivers side with the hella one from FCP. It’s identical.
cerealwars78.00 |
12-04-2023, 09:55 PM | #13 |
Rep 231
Lester Thanks for the hint, but those are $$$. At this point, I just want to spend what's necessary to keep this old car in working order, nothing more.
Converted1 Thanks, I will order the Hella one. |
12-06-2023, 09:50 PM | #14 |
Rep 231
Today the "brake light error" warning returned. Here's a pic:
[IMG]IMG_3164 by dgua, on Flickr[/IMG] The error message seems misleading. The brake light works just fine. I think what this message means is, there's a problem with the "outer brake light" circuit, and that is what is preventing the LED from working. Before I order the replacement light, I will apply 12V to the leads and see if the LED still works. |
GoRomeo963.50 |
12-07-2023, 08:47 PM | #16 |
Rep 3,854
Drives: 330i, 135i
12-09-2023, 02:16 PM | #17 |
Rep 231
Today I removed the tail light.
It is now clear how the LED running light works: it gets fed from two additional contacts at the "outer brake light" socket (the other one is at the opposite side): [IMG]IMG_3177 by dgua, on Flickr[/IMG] You can see the two wires (red and brown) going into a small LED board at the upper right corner here: [IMG]IMG_3176 by dgua, on Flickr[/IMG] I have verified that, when the running lights are turned on, the voltage at those terminals is ~14.3V. When I feed 14V to those contacts with a power supply, the LED does not turn on. It's 100% clear now that I need a new tail light. |
SilverM2_CS103.00 |
12-22-2023, 09:47 PM | #19 |
Rep 231
Today I installed the Hella replacement light (from Rockauto), and that fixed all problems.
The part is identical to the OEM one, except it does not have a small BMW logo where all other details are printed on the black part that is visible when the trunk is open. I am sure both parts are made in the same factory. |
