      01-03-2018, 07:15 PM   #1
rowsdower
rowsdower's Avatar
641
Drives: 2011 128i 6MT Sport
Valve cover gasket leak
I have a 2011 128i 6MT N51 with about 80k miles on it. My valve cover is leaking and I am researching replacement. Looks fairly straightforward, just time consuming. In what I'm reading, it looks like lots of people are replacing the eccentric shaft sensor while they're in there. Is it wise to replace the sensor itself or just the gasket? I can't seem to find the sensor on RealOEM, but I think #3 the gasket. Am I right?
https://www.realoem.com/bmw/enUS/sho...diagId=11_3737
Any other items I should be replacing as part of this project?
      01-04-2018, 07:23 AM   #2
bionicbelly
Drives: Z3 coupe, 128i
I would just do the sensor. #3 is not the gasket that you need to worry about. (although it is a good idea to change it also) Check out FCP euro, they have lifetime replacement and good prices. While you are there, Get the full head gasket set (Does not come with a head gasket) it will get you the valvetronic motor gasket, intake manifold, throttle body, and a bunch of others, including the oil filter housing gasket. I did them all, but I did have a couple of other things to do while I was in there.
Pro tip- the rubber boots that seal the strut tower braces at the cowl will come out, and it gives you that extra little bit of room to get the valve cover gasket off.
Also-Pelican parts has a really good write up on this job.
      01-04-2018, 09:11 AM   #3
m_thompson
m_thompson's Avatar
Drives: M-Sport 128i, 328xi, 3.0CS
2009 128i  [0.00]
1972 3.0CS  [10.00]
Is the leaking valve cover gasket covered under the extended SULEV warranty?
'09 128i - Black Sapphire Metallic\Coral Red\Glacier Silver\N51 DISA\6MT\Navigation\Premium\M-Sport\Heated seats\Xenon\Headlights\iPod\Smartphone\Euro Delivery
      01-04-2018, 07:08 PM   #4
rowsdower
rowsdower's Avatar
641
I just read up on this, and I think you're correct! It should be covered for anyone with a car registered in a SULEV state. Unfortunately I'm in Texas now, so even though the car is SULEV, BMW won't honor the warranty (confirmed with 2 dealers' service departments). So I'll be doing this job myself.
      01-04-2018, 07:09 PM   #5
rowsdower
rowsdower's Avatar
641
Thanks for the tip about the gasket set!
      01-05-2018, 06:06 AM   #6
bionicbelly
Absolutely! It is a good size job, but it is not very complicated. Just time consuming. It was the first time I had worked on my 1'er in depth, and as always, BMW's are just fun to work on.
Couple more tips, if you get the gasket set, there will be two green O-rings. They are for the vanos solenoids on the front of the head. Mine were leaking badly, so do those as well. It is a good time to clean those really well, and clean out the vanos filters on the passenger side of the head. Lots of info out there for that job. My 128's were fine, but I did an E90 a few weeks later that had one filter completely gunked up.
