11-24-2008, 05:42 PM | #1 |
HALA MADRID!
940
Rep 2,879
small High pitch sound...what is it?
last few days I noticed that my car starts to make this somewhat faint yet audible high pitch tone, specially after a few runs above 4k rpm. I muted the radio, and I can hear it but can't pin point where is coming from.
I opened the windows and doesn't seem like its coming from the outside/engine bay of the car. Looks more and more like within the AC/fan system. anyone heard of this issue or has experienced this?:iono:
F87 M2 Competition, Sunset Orange, Exc, DCT. **SOLD** F80 M3 Mineral Grey/Sakir Orange, Exc, DCT... ED 6/2015 **SOLD**E90 M3, Interlagos Blue / M individual two-tone, ZCP, ZP2, ZCV, DCT, ED. |
11-24-2008, 05:48 PM | #2 |
Rep 280
You're sure you're not hearing the turbos?
2008 135i Performance suspension, exhaust, grilles, front bumper, skirts, shift kit, spoiler. M3 front control arms, rear subframe bushings. Cobb'd. |
11-24-2008, 05:55 PM | #3 |
HALA MADRID!
940
Rep 2,879
since when were the turbos audible? NEVER did I hear them before...:iono:
11-24-2008, 05:57 PM | #4 |
Engineering Tool
Rep 152
Could be the fuel pump
135i M-sport Convertible <> Monaco Blue, Lemon Interior, Brushed Al Trim, Black Rag, Hi-Fi, Pro Nav, Front/Rear PDC, BMW Performance SSK
Due December 15th! |
11-24-2008, 06:02 PM | #5 |
Rep 206
11-24-2008, 06:02 PM | #6 |
HALA MADRID!
940
Rep 2,879
that was my first thought, but when I opened the windows, I couldn't hear it. But I will double check again.
dammit, i hope is not the FP's
11-24-2008, 06:04 PM | #7 |
HALA MADRID!
940
Rep 2,879
no. why is that strange? i would have heard them since day one.
11-24-2008, 06:06 PM | #8 | |
Rep 280
But, then, I can tell the difference in a half-pound of tire pressure on the track, so maybe I'm overly sensitive.:iono: If the high-pitched sound goes up and down with speed, it's probably something electrical. But if you hear it and it quits when you suddenly cut the power, you're probably just hearing the turbo whine.
11-24-2008, 06:12 PM | #9 |
HALA MADRID!
940
Rep 2,879
it doesn't go up and down with speed per se, but if I'm at a stop I hear it, but when I engage 1st gear and start to go, it goes lower...once I pick speed, it goes back up.
11-24-2008, 06:21 PM | #10 |
Rep 280
If you hear it idling at a stop, it probably isn't the turbos - they're pretty much doing nothing at that point. It sounds electrical - do you get it if you kill power to the radio? Do you have iDrive?
11-24-2008, 07:34 PM | #12 |
Rep 7
I hear all sorts of high pitched sounds from my car. Especially when a CD is in the car, whether or not it is playing. It is NOT the turbos or fuel pump, because it also occurs when the car is off.
There are also bugs within the door gong/seatbelt chimes. Sometimes they just cut out before finishing the sound. Annoying, but I don't really see how they would fix these things. |
11-24-2008, 08:42 PM | #13 | |
HALA MADRID!
940
Rep 2,879
one interesting point: i just started using the CD player yesterday (only iPod, etc, before), so it could be the CD...i will check in the morning
11-25-2008, 09:14 AM | #16 |
Rep 13,043
Drives: BMW M340I G20
I hear some kind of pump/motor running even when I only run the engine for a minuet
11-25-2008, 09:53 AM | #17 |
Rep 564
11-25-2008, 10:03 AM | #18 | |
Rep 5,970
Try pressing the re-circlulation button on the HVAC controls and see if it goes away. My car has an issue with the re-circ flap not opening properly sometimes, and it causes a whistling noise at speed when it's pulling in outside air. Turning it back to re-circulation mode gets rid of it instantly. The button also does nothing when the A/C compressor is turned on, so that may be an additional symptom to look for. I'm taking it in to have the dealer look at it in early December, I'll report back once I do. |
11-25-2008, 10:13 AM | #19 |
Rep 13,043
11-25-2008, 10:16 AM | #20 |
Rep 187
OK. I have this noise and there was a big discussion on this a while back.
If the noise sounds like its from the Dash (passenger side) then its the water pump. Its a known issue, and it makes noise, like a high pitch hum almost. It will come on when Idle and when driving. You just cant hear it when driving because the engine noise is louder. The 3 series has the same issue. Its not a problem, just there by design. They didnt do a good job padding it out. Let me know if thats the sound. It should sound like a high pitch motor sound. If so, its the water pump. |
11-25-2008, 10:27 AM | #21 |
Rep 187
Mayeb this will help: http://www.1addicts.com/forums/showt...ght=water+pump
11-25-2008, 11:57 AM | #22 | |
HALA MADRID!
940
Rep 2,879
so, from your post and link, sounds like it is the Fuel pump design, and doesn't need replacing. Is this correct? :iono:
