      09-16-2018, 09:22 PM   #1
old grunt
Drives: 2011 135 I/M
oil cooler
I've done some digging but find not much for aftermarket (larger) oil cooler, currently run about 230-250 degrees, which makes me a bit uncomfortable.
      09-16-2018, 10:06 PM   #2
chris_flies
Sideways and Smiling
chris_flies's Avatar
3027
Drives: In Exuberance
230-250 is normal for the 135i. The small turbo(s) are always spinning and heating that oil. There are quite a few kits that change the oil cooler fittings from BMW lines to -10AN lines, which you can then use with a universal oil cooler...
      09-16-2018, 10:10 PM   #3
old grunt
Understood, Thanks for the response.
      09-18-2018, 09:46 AM   #4
Matticus91
Matticus91's Avatar
Drives: 2013 135i
There are aftermarket coolers you can get as part of the BMW Performance or Dinan kits, if you want something serious. On the lesser end you can get a lower temp thermostat from BMS or a few other vendors that seem to work decently.
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq
