04-28-2019, 01:29 PM | #1 |
Rep 57
Help! Broken N54 Valve Cover Bolt Extraction
My torque wrench failed me and broke off one of the bolts. There is not much head room for me to clamp the bolt out.
The bolt is easily accessible, but I have been trying to use 1/8 drill to drill the bolt, but the lack of precision and moving around makes it very scary (don't want to destroy the engine block). I've been searching around- mostly found concrete answers for the aluminum bolts on the N52. Any ideas and suggestions? Thanks! |
04-28-2019, 09:54 PM | #2 |
Rep 1,916
Years ago snapped a bolt replacing my water pump on a 5.0 Fox body. My buddy welded a bolt onto the broken bolt and extracted it. That was a steel bolt and block but maybe you can get a good TIG guy to work some Al magic. Good luck
"The Constitution was never construed to authorize Congress to infringe the just liberty of the press, or the rights of conscience; or to prevent the people of the United States, who are peaceable citizens, from keeping their own arms.” Samuel Adams |
04-28-2019, 11:23 PM | #3 |
Rep 3,148
There's a few different techniques that could be used
Use a sharp punch and punch the surface of the screw near the edge at a shallow angle, to try and reverse the screw out. Ive done this with snapped oil pan bolts before Centre punch the hole and try to drill a small hole in there, then once the hole is started run a screw extractor on it. (Alloy screws only) Drill hole into the screw then hammer in a torx socket in the hole, then use a ratchet to back out the screw
04-28-2019, 11:30 PM | #4 |
*Rollin 3rd*
106
Rep 1,232
Not my video but this is how I extract called a punch I believe. I usually do the second way smacking a good size torx bit and working it out slowly if I don't have space. Start with method one if you have space move to torx bit if it doesn't work out. Worst case scenario heli coil. Hardest part is getting the gumps to get a drill near the head but once you're over it you realize its just another repair. Hope this helps. |
04-29-2019, 09:00 AM | #5 |
Rep 992
In that situation I like the punch idea followed by a small drill bit and then a screw extractor. You might even use a hand drill to start the hole. It should be fairly easy to get out since you just had it out. Have someone stand next to you with a vacuum while you drill and take up any filings as they are produced.
04-29-2019, 11:26 AM | #6 |
Rep 439
Ah a lucky one. I would recommend the left hand drill bits if you can find them.
2008 SGM 128i - 3 Stage IM - 130i Tune - Dinan Camber Plates - BMW PE - Injen Intake - 1M Mirrors - LCI Blacklines - M4 Spoiler - Blacked 263's - Aero Bumper - Aero Side Skirts - OMGSplitter - AFE Intake Scoops
05-03-2019, 09:46 AM | #8 |
Boost Addict
335
Rep 1,244
I did this same thing exactly. Got it out using a sharpened screw driver and a ball peen hammer, took me about 30 seconds.
https://www.1addicts.com/forums/show....php?t=1493684 |
