06-22-2017, 11:23 AM | #1 |
Rep 202
Transmission fluid change in high mileage 1
Been going through a bunch of DIY's for the transmission fluid change and am pretty confident that I can tackle this job myself.
I have decided that Ill be using Redline D4 ATF. My ONE concern is that I don't know the last time the transmission fluid was changed if it was changed since its a lifetime fluid (BS BMW), i purchased the car in May 2015 @ ~127,000 miles and have since put on a good amount of miles, sitting at ~150,000. Only one previous owner that had the vehicle serviced regularly at BMW. Should I be concerned about changing the fluid, or am I just being a little careful. I can only imagine how disgusting the fluid must be. Car is a daily I use to travel from Manhattan to Brooklyn daily, lots of NYC traffic. Shifting is decent, never slips but is quite notchy/rough especially in 1st. Any ideas, recommendations greatly appreciated. |
06-22-2017, 05:57 PM | #3 |
Rep 202
06-22-2017, 10:03 PM | #4 |
E82 Mudflap Ambassador
2214
Rep 2,219
Drives: '08 128i
Get ready for the smell
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
06-26-2017, 08:54 AM | #5 |
Rep 202
06-26-2017, 03:40 PM | #6 | |
Rep 4,341
Anyway, get a sqeeze bottle with pickup at the bottom and a 12-18" hose to sqeeze the fluid in. It's a great DIY. Also, you should change the DIFF also. Again, I would use OE for that too. Best wishes. |
06-27-2017, 05:22 AM | #7 |
Level 1 BMW Tech
25
Rep 62
If it's an auto trans, leave it alone. If it's a manual, it's real easy. Just make sure you can loosen the fill plug before you touch the drain plug. You'll be SOL if that fill plug is seized and you've already drained it, know what I am saying?
Options: Sunroof delete, Sport Package, Xenon
Mods: M Performance Suspension, BMW Style 197 Wheels/ PSS Tires, M Sport Steering Wheel |
06-27-2017, 07:04 AM | #8 |
Loves me some MHD!
1858
Rep 1,719
Auto is easy to do as well, just a few more steps & some additional cost involved. At high mileage there are a few solenoids & extra seals that should be replaced as well, but again all easily accessed & replaced.
There's a great DIY for the automatic here.
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla . . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg |
06-27-2017, 09:33 AM | #9 | |
Rep 202
1and11858.00 |
06-27-2017, 09:44 AM | #10 |
Rep 317
06-27-2017, 11:52 AM | #11 |
1Addict
3234
Rep 7,894
For manual:
1. Jack car & secure on stands 2. Remove transmission belly pan 3. Locate transmission case and drain/fill holes. 4. Remove Fill bolt 5. Place drain bucket under transmission 6. Remove Drain bolt 7. Catch all fluid in bucket 8. Replace drain bolt 9. Use transfer pump or suction gun to pump new transmission fluid into fill hole until it JUST dribbles out. 10. replace fill bolt 11. replace transmission belly pan 12. lower car I like this suction gun for transmission fluid changes: https://www.harborfreight.com/automo...gun-95468.html
06-28-2017, 09:09 AM | #12 |
Rep 202
*UPDATE* Fluid changed I am very surprised my fluid did NOT smell foul whatsoever (new stuff didn't smell good) and was not as filthy as i thought it was going to be. Shifting feels very smooth and I am very happy that this job is done, on to the next !
1and11858.00 desertman1232213.50 |
Tags |
flush, redline, transmission, transmission fluid change |
