      01-29-2022, 12:18 AM   #1
racer_951
Drives: e92 M3, Cayman S, 128i MS, SPB
Can you install 135i oil cooler on N51 128i
I was searching for 128i oil cooler installation. I came across a YouTube video. This dude said 135i oil cooler won’t fit N51 128i, but N52 is ok. If so, what options do we have for us N51 people.
      02-06-2022, 10:36 PM   #2
gixracer
gixracer's Avatar
Drives: 1M3/SlickN55/SlickN54/128
Yep more cooling = more better.
2 piece Oil cooler housing
Lines
Radiator
Mounts
Lines
And fittings
Make sure to have proper ducting to radiator otherwise it’s a waste
128i Msport, 1M3=1M clone +S65= N55 swapped former 128 slicktop, former 128 slicktop with N54T swap
      02-08-2022, 11:31 AM   #3
wootloops
wootloops's Avatar
356
Drives: 2013 E92 M3 Lime Rock Park
It can fit on the N51... someone on here or e90post did it.. there was something that had to be bent slightly to make space, like an A/C line or something due to the secondary air pump being in the way of the normal path (if I recall correctly).
      02-08-2022, 11:42 AM   #4
racer_951
In that case, I might remove the secondary air pump. Thanks
      02-18-2022, 07:52 AM   #5
wolfe
wolfe's Avatar
134
Drives: e82 / e70 / r56 / r60
You can also install the oil to water heat exchanger pretty easily.
      02-18-2022, 08:11 PM   #6
racer_951
Since I already bought all the parts for a 135i oil cooler retrofit, I’ll go with that path. Had I know there is a heat exchanger option, I would have gone down that path first.
Also, for those who did the 135i oil cooler, how do you air flow on the 128i to cool the oil cooler? The 135i has an opening on the lower right corner of the front bumper. But the 128i doesn’t have that opening.
Photos will be helpful.
      02-19-2022, 09:29 AM   #7
spidertri
spidertri's Avatar
Drives: 11 128i 6MT Sport
2011 BMW 128i  [0.00]
Most people have an 128i Msport that have the 135 bumper already installed. Then they just buy the appropriate pieces to make the oil cooler duct functional.
I only have a sport with the base front bumper which is a big part of the reason I went with a custom cooler to the lower center grille opening.
11 128i slicktop
13 WK2
19 Alltrack S
      02-19-2022, 09:51 PM   #8
Alow
Alow's Avatar
38
Drives: E82 128i, F36 430i GC
I have the 135 oil cooler on my 128 as well. N52. for the cooling ducts I have the bmw performance bumper so just bought the plastic scoops to direct air to the oil cooler when they were still available.
