      10-17-2019, 12:19 PM   #1
Gartho
Drives: 2010 128i 6sp Sport
New to me 128i fluid change info needed
2010 128 6SP manual...102k
My power steering is leaking all over...So I ordered a new filter/container and will flush it with the green 11s.
I saw that I needed an air filter and cabin one so I ordered all that on one order.
So it got me thinking...trans and rear diff and coolant...
Could you tell me what the capacity if for each and what is the best type to get?
Now Brake fluid...I plan on tracking my car so I was told to get a higher temp fluid and better brake pads...So what is a good fluid?
Thanks in advance!
Garth
I never seem to be able to search these forums right so sorry if its here and I cant find it.
      10-17-2019, 01:17 PM   #2
one 35i
one 35i's Avatar
Drives: CSM/terra
fluids and parts
try online getbmwpart.com or pelican parts. They have good info and all of the fluids etc.
      10-17-2019, 02:09 PM   #3
spidertri
Drives: 11 128i 6MT Sport
I like using Motul RBF600 for brake fluid on the track (and daily year round too). I haven't experienced any fade, but I do bleed the brakes before each event just to make sure the system is good to go.
As for brake pads, it's somewhat dependent on your track experience. Have you done track days or just starting out?
Here's a thread on changing the diff and trans fluid.
https://www.1addicts.com/forums/showthread.php?t=409293
Coolant change info, sounds like for just a drain and fill you'll need one gallon of BMW coolant and one gallon of distilled water, create 50/50 mix and refill.
https://www.1addicts.com/forums/show....php?t=1370689
11 128i Space Gray slicktop
98 328ti Morea Grun slicktop
      10-20-2019, 11:25 AM   #4
Gartho
Thanks!
Copyright ©2000 - 2019, vBulletin Solutions Inc.
