      01-10-2022, 08:27 PM   #1
Crazy Legs
Shredded Serpentine Belt, PS Pulley Issue... Need Advice
So as I was driving I heard a weird knocking sound coming from my engine bay, so I limped my car the rest of the way home. When I look under the hood, I see that my serpentine belt had started to shred with strands of belt wrapped around the alternator pulley and power steering pulley. I also noticed that the bolts on the power steering pulley were loose. I did some research and learned that this is a common issue for early model 135i's, and mine is a 2008.
So I order a new aluminum PS pulley and serpentine belt, but when I go to install the PS pulley I notice that 2/3 bolts are free spinning on the hub, and can be moved back and forth when screwed in halfway.
Does anyone have any recommendations on how to salvage this issue? I really don't want to have to replace the entire power steering pump, since I haven't been having any squeal or steering issues. Based on the picture I took, do you think I could get away with getting longer bolts and using a nut to secure it behind the hub?
power steering pulley, serpentine belt, shredded belt
