11-11-2014, 12:07 AM | #1 |
Rep 1,310
opened engine oil cap & smell like gas?
As i was coming back home from work i pulled into my driveway and opened my engine oil cap and smelled like fuel . is this a sign of fuel injectors leaking ?
MHD Custom Flash (E85) [Jake@MOTIV] / Vargas Stage 2 Turbos / Fuel it LPFP Stage 3+/ Moitiv Port Injection/ MMP Turbo Inlets/ 3.5 Tmap Sensor / ER FMIC /ER Chargepipe HKS-BOV / AA Downpipes / Agency Power Race mid pipes / Berk Technology race exhaust / BMW SSK / BC Forged Whees Toyo R888 tires / KW Club sport coilovers+KW Camber Plates / Spec stg2+Spec SMSFW/ APR Wing GTC200
11-11-2014, 04:22 AM | #2 |
Rep 182
This is typically either piston or valve seal blowby. common on turbo cars as they age. This can also happen if you have a injector that leaks after car shuts down.
11-11-2014, 05:02 PM | #3 | |
Rep 1,310
11-12-2014, 05:10 AM | #4 |
Rep 182
Well to much of this is not normal. To much gas in the oil can reduce the oils effective viscosity. I would do a compression check. If it looks good then your probably alright, mmay want to use 1 level heavier weight oil.
11-12-2014, 10:31 AM | #5 | |
Rep 1,310
11-12-2014, 10:55 AM | #6 |
2020 Z4 M40i - 2022 M4C Convt
3157
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Lots of short trips?
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
11-12-2014, 11:22 AM | #7 |
Rep 722
11' m57 335d 165k Miles - JR 2, ATM Full Exhaust & Intake, Wagner FMIC, AAR Boost Pipe, AAR Swirl Delete, AAR EGR Delete
08' n54 135i FBO E85 - SOLD |
11-12-2014, 11:38 AM | #8 | |
Rep 22,992
It's almost winter so there is no point in running a 40 weight oil. Just change your oil and report back. Dack
11-15-2014, 11:15 PM | #9 |
Rep 1,310
40 degree today perfect timing to get my oil change
11-23-2014, 04:52 PM | #10 |
Rep 116
Might be worth doing a Blackstone oil report?
JTB
Spec Miata - 2nd SCCA RMDiv 2014 Spec Miata - 2nd SCCA RMDiv 2013 2009 135i - let the modding begin! |
11-23-2014, 07:15 PM | #11 |
Rep 260
I had a leaky injector and now I have to rebuild my motor, send a sample to Blackstone!
08 135 SB
DCI, VRSF 7" fmic, VRSF DP, Berk street, Wavetrac!, Koni yellows, eibach sways, M3 lca, Dinan plates, poly bushings, JB4 iso5, E85, Alpina flash/m3 paddles, CP, walbro, and other crap. VVT Stg1 |
11-26-2014, 03:16 AM | #12 | |
Rep 1,310
i just got a new oil change about a week ago is to early to take a sample and send it to black stone?
11-26-2014, 03:34 AM | #13 |
Rep 22,992
Does your oil cap(after a drive) still smell like gas now that you changed your oil?
11-26-2014, 09:20 AM | #14 | |
Rep 260
Just watch your oil level carefully
08 135 SB
11-26-2014, 02:00 PM | #15 |
Rep 1,310
good thinking. i will do that after a good drive to see if it still smells
12-01-2014, 01:49 PM | #16 |
Rep 2,346
any updates?
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms |
12-01-2014, 03:45 PM | #17 |
Rep 1,310
Will check tonight
12-01-2014, 10:37 PM | #18 | |
Rep 1,310
today after a drive oil temp. at 240 i opened my engine oil cap and it smelled like gas again. but the smell went away
