01-26-2021, 10:06 PM | #1 |
Rep 173
cranks but won't start
Hi, it's been a while since I posted. Having issues with my 1M, engine cranks but won't start. Vehicle has 20,000 miles, no mods.
Last time I drove it, it started up right away and that was 1-2 months ago. Battery is on a trickle charger 2 days (weekends) a week. I connected a battery pack jumper to the jumper post in the engine compartment thinking the battery voltage was low causing lower cranking speed but still won't start. No check engine light. I checked the fuses related to fuel behind the glove box and all seem fine. I noticed the priming of the low pressure fuel pump is not happening when I unlock the doors. Defective LPFP/fuel control unit or something else as simple as a fuse or a relay? Next, will be checking all the fuses behind the glove box before I check the LPFP Richard |
01-27-2021, 07:29 PM | #2 |
Rep 23
If you hook the trickle charger up, does it have an indicator which confirms that the battery has a full charge? Is your battery jumper fully charged and sufficiently powerful to instantly fire up the engine? I’m still hoping it’s something simple. Good luck.
01-28-2021, 07:50 PM | #4 |
Rep 8
I have the p3 gauge plugged into the OBD port and one time it happened to me that it would just crank and not start.
Reseated the p3 cable at the obd port and all good not sure if you have anything plugged in but that’s my 2 cents Good luck |
01-29-2021, 12:41 AM | #5 |
Rep 173
Yes battery charger is a pulsetech XC100-P it has a meter that tells you what percent of the battery is charged. Meter shows 100% Battery pack also has a screen showing 100% charged.
01-29-2021, 12:42 AM | #6 |
Rep 173
01-29-2021, 12:43 AM | #7 |
Rep 173
I have nothing plugged in the OBD port
01-29-2021, 12:47 AM | #8 |
Rep 173
Checked all the fuses behind the glove box with an ohm meter, all good. Will be checking the fuel control unit by the rear passenger seat back. Hopefully this is it, maybe something weird happening at the connection.
01-30-2021, 11:39 AM | #9 |
Rep 324
Based on my limited mechanic abilities (but not afraid to attempt work above my pay grade), and you mentioning that you don't hear the LP prime pump upon doors unlocking, I'd say concentrate on why that's not happening.
‘If it even looks like rain and you pretend to be Michael Schumacher in a 599 GTO, you’ll end up in a tree’ -Clarkson
01-30-2021, 11:41 PM | #10 |
Rep 2,819
Drives: e82 1M, f87 M2cs
Agreed . . . sounds like a fueling issue. OP, do you smell fuel after cranking? If you have a no spark issue, the exhaust will smell like gas after a few long cranks.
01-31-2021, 05:57 AM | #11 | ||
Rep 173
Daz116.50 |
01-31-2021, 07:26 PM | #12 |
Rep 8
fuel pump seems logical if you can't hear it. please post the fix. interested to know the outcome. good luck!
02-01-2021, 08:36 AM | #14 |
Rep 173
No check engine light so I assume no codes. I got access to the fuel control unit (EKPM), just thought I unplug and replug it but still the same. Will check on the fuel pump and test it. If my fuel pump runs by connecting 12v to it then it's most likely the fuel control unit. When you replaced the fuel control unit (EKPM) on your other N54 did you have to program (register) the new unit in?
02-02-2021, 01:11 AM | #15 |
Rep 77
Just because you dont have an engine light, doesnt mean a shadow code wont be triggered or a fault isn't present. For me the first two steps is always to read the codes and then if possible or viable do a log.
Secondly , yes the EKPM needs to be coded, especially if its a new item Last edited by Boost3d_1M; 02-02-2021 at 07:08 AM.. |
03-02-2021, 06:18 PM | #16 |
Rep 173
Tested the fuel pump and it's good but somehow the sound didn't seem to be coming from where the fuel pump is located (under the rear passenger seat). I can barely hear the fuel pump prime when I push the start/stop button without depressing the clutch pedal.
It was a bad camshaft position sensor (intake). The original one was not putting out any signals when I placed a metal object to it. Started right up after replacement. |
03-02-2021, 06:21 PM | #17 | |
Rep 173
03-02-2021, 06:31 PM | #18 | ||
Rep 2,819
03-03-2021, 06:08 PM | #19 | |||
Rep 173
