06-14-2017, 03:33 PM | #1 |
Boost
1349
Rep 3,689
Drives: 135i M-Sport
Rear Manzo Camber Arms
Any reviews? What's the max negative camber people are getting with these?
06-14-2017, 06:12 PM | #2 |
Rep 160
Drives: 2010 128i
I am in no way trying to be a troll... but how much rear camber are you looking for? I have -2* and room to go further with the factory eccentric bolts.
06-14-2017, 07:09 PM | #3 |
Boost
1349
Rep 3,689
More looking for ease of adjustment tbh
06-14-2017, 08:32 PM | #4 |
Rep 987
I want to say it made a difference with rear end stability. Changes made at the same time were, going to -2 deg from -1.7 deg camber and going from MPSS to Direzza Z2SS.
Car no longer wheel hops when spinning- feels more planted too, I think. Toe spec will change a little while tightening down the adjustment nuts. It can be a little frustrating to get just right.
MHD | BMS | VRSF | APEX | RECARO | TC Kline | BERK | Turner Motorsport | Eibach | BMW Performance
07-18-2017, 08:53 PM | #6 | |
Boost
1349
Rep 3,689
I don't think I'll end up installing the camber arms, I found a good deal but they don't seem to add much performance if you can get -2* out of the stock setup. I also have a set of the black Powerflex rear position subframe bushings to install to replace my current subframe inserts - I don't see an issue running just the rear position with only inserts on the front bushings? This would make the DIY a lot easier but may increase wear on the rear bushings...
