10-19-2011, 08:36 PM | #1 |
special
35
Rep 857
which front sway bar for a 128?
I see at least three options for adding a front sway bar to a base model 128i:
1) The 135i stock sway bar 2) The 128i sport package sway bar 3) The M3 sway bar There are probably some non OEM options as well. Here's my question: How to choose/differentiate between them? |
10-20-2011, 08:13 AM | #4 |
special
35
Rep 857
Is the Dinan one not "too stiff," so I don't need to do the rear as well? My goal is a little less roll around hard corners, but I'm not really looking at the other elements of a sports suspension, since this is a DD, and I have to drive over a lot of speed bumps every day...
10-20-2011, 09:05 AM | #5 | |
P1
Rep 106
'86.5 325eis Track Ho | '08 128i Daily | '16 Tacoma
10-20-2011, 09:08 AM | #6 |
Rep 283
10-20-2011, 09:59 AM | #7 |
Unloved BMW Addict
86
Rep 1,185
Drives: Z3 Coupe, 3 318Ti
e92 M3 is what I have and I love it.
Others have said that if that is all you want to do, it's the best choice. |
10-20-2011, 12:27 PM | #9 | |
Rep 283
So all in all, I wonder if putting a thicker front sway without a rear would mess up something in the driving characteristics. |
10-20-2011, 01:31 PM | #11 | |
Cone Cruncher
31
Rep 534
The front is very easy to install yourself. The rear is far more difficult. If you want a front sway, you shouldn't go overkill unless you balance with e93 rear, which will result in a super stiff car and you should be changing out the rest of the suspension to match. |
10-20-2011, 07:40 PM | #12 | |
Damenslip-Tropfer
23
Rep 543
10-20-2011, 10:08 PM | #13 |
Rep 2,233
Here's a good DIY to follow. I went with the M3 Coupe swaybar, the M3 convertible bar is 2mm thicker.
http://www.1addicts.com/forums/showthread.php?t=217262 |
10-20-2011, 10:23 PM | #15 |
special
35
Rep 857
Good info. I just want an incremental improvement in handling and sway in cornering in my DD. It's a non sport 128, and won't ever see a track. And at this point I am not interested in something complicated like the rear bar, or replacing the whole suspension.
So it sounds like I should get the most light weight front sway bar available. Would that be an oem 135i sport front sway bar? Both the 135 and 128 "stabilizer" appears to be 26.5mm if I am reading realoem correctly. Last edited by nato-main-man-5am; 10-20-2011 at 11:04 PM.. Reason: turned a statement into a question |
10-21-2011, 12:00 PM | #18 |
Unloved BMW Addict
86
Rep 1,185
e92M3. You won't regret it.
it's a minor tweak. |
10-23-2011, 01:59 PM | #19 |
BMW: intake,exhaust,strut bar,18''M1styl,CFspoiler
Rep 102
BMW Performance
I went with the oem bmw performance strut(non-carbon fiber), im pretty sure its aluminum... luv it, great results!
10-24-2011, 12:27 AM | #20 |
special
35
Rep 857
A little more poking around realoem and it seems like even the non sport 128 has a sway bar of the same diameter as the sport model and the 135. Maybe they are made of different materials?
10-24-2011, 01:59 PM | #21 |
Rep 254
There might be a "kink" in the 128i / non-sport 135i bar that reduces the "real" circumference of the bar to something less than 26.5mm.
I know that's the case with the M3 (e92) bar and the 135i sport one. The latter has a kink which reduces its circumference, even though it "measures" the same as the M3 e92 one (i.e. 26.5mm).
cdv delete | clutch stop | bmw performance ssk | meisterschaft gt | berk mids | dinan cai | helix fmic | m3 subframe bushings, swaybar, front and back suspension bits | dinan stage 1 suspension | dinan cf strut brace |gc camber plates | dinan oil cooler | apex ec-7s w/PSSs | cobb stage 1 + fmic
10-24-2011, 02:14 PM | #22 |
special
35
Rep 857
Ah, and such variations of course impact how the bar performs.
I wonder how to characterize the differences in performance and handling between the stock 128 (non sport) sway bar with the 135 sway bar -- especially if one leaves the stock base model sway bar in back and only puts the 135 sway bar in front. |
