05-22-2013, 10:35 AM | #1 |
Rep 51
1M Trailering...
Ordered a new enclosed car hauler and have been looking at ways to secure the car to the deck.
Anyone have experience here? Esp. the track guys? The 1M is so fun I'm sure most people drive to the track, but someone must have had to secure it on a trailer. I've read about the available T-Hooks (Pierce Arrow) that attach in the holes for the Jack Pads, and it sounds good (Used on E36/E46). Any trailering advice, let me know. I'm not prepared to put straps around the delicate aluminum control arms, etc... |
05-22-2013, 10:38 AM | #2 |
Rep 324
I've seen a type of ratchet strap that is sort of a webbed design that goes around the entire tire. That way no tension on the suspension bits. Have no idea where to find them.
‘If it even looks like rain and you pretend to be Michael Schumacher in a 599 GTO, you’ll end up in a tree’ -Clarkson
05-22-2013, 11:07 AM | #3 |
Rep 11,785
i had made a previous post about this... let me see if I can find it.
http://www.1addicts.com/forums/showt...hlight=trailer I added a post to the other thread as well. Hope this helps. Last edited by M3 Adjuster; 05-22-2013 at 11:33 AM.. |
05-22-2013, 03:07 PM | #5 |
Rep 1,358
Roll your enclosed trailer with wheel straps and best case scenario the entire suspension is completely trashed and likely one side of the car is smashed up.
Roll an enclosed trailer using t-hooks and best case scenario all you'll need to do is clean up some oil that leaked out the top of the oil cap. Food for thought. |
08-20-2013, 10:53 AM | #6 |
Rep 51
Here is the trailer that I ordered a couple of months ago from Proline Products LLC. in Milton, New Hampshire. It is an 8.5 X 18 Car Hauler with a few extra options. It fits the 1M perfectly, and doubles as a trailer when I want to go comping on the weekends.
It's fully insulated with Silverboard rigid foam insulation, and the cabinet in front has an Sirius Equipped infinity car stereo, RV Power Distribution center (120 Volts and 12 Volts) and a 1500 watt fan forced heater. Fully loaded it comes in just under 7000 lbs. I tie it in using the J hooks on the rocker panel holes with 10,000 lb ratchet straps and it does not move. |
08-22-2013, 09:42 AM | #8 |
Rep 3,450
08-23-2013, 12:18 AM | #10 | |
Rep 38
Drives: 2011 1M
Garage List 2009 BMW X5 [0.00]
2002 BMW M5 [0.00] 2018 BMW X1 [0.00] 1990 325i Sedan [0.00] 1995 540i M Sport [0.00] 2011 1 Series M Coupe [10.00] |
Not sure that such an extreme situation is a primary consideration for tie down solutions but good info nonetheless! |
08-23-2013, 01:42 AM | #11 | ||
Rep 11,785
