08-03-2014, 01:53 PM | #1 |
Rep 306
Bmw 135i brakes (grey brembo's) fitment on bmw 125/128i
So I came to a point where i have to change my front rotors and found a great deal on a set of 135i brembo brake kit (not the performance ones). Now question is, will they fit straight on on a 125/128i or Am I going to have a hard time doing custom brackets and all of this stuff?
Thanks in advance |
08-03-2014, 07:34 PM | #3 |
Rep 4,040
Drives: 130i coupé ;)
The front is Swap straight.
The rear - you will need to bend your Dust shield/heat shield back. They bolt on 100% but the hand brake doesnt work Custom brake shoes are needed - see my posts in 128i section - "128i no love / or 128i love thread" Alternitively e46 m3/e60 hand brakes may be made to work using info from my posts
08-04-2014, 01:54 AM | #4 | |
Rep 306
And regarding front bolting straight on, aren't the disk brakes bigger than my 300mm? |
08-04-2014, 12:13 PM | #7 |
Resident Tamed Racing Driver
298
Rep 4,697
Are you overheating the stock brakes as indicated by braking performance that becomes more and more reduced(longer and longer stopping distances)?
08-04-2014, 12:34 PM | #8 |
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.22] |
Who doesn't fade stock brakes? If you're not fading, you're not driving. If you're not driving, you're not 1addict. If you're not 1addict, you're not enthusiast. If you're not enthusiast, you're not "because racecar". Therefore because racecar = fading stock brakes.
08-04-2014, 12:54 PM | #9 | ||
Rep 306
08-04-2014, 12:59 PM | #10 | ||
298
Rep 4,697
08-04-2014, 01:26 PM | #11 | |
Rep 306
which by that term I mean that I have to decelerate quite often and harshly as my driving style isn't quite the best of economy and safety. apart from 135i brakes what else is there availble that will fit? will m3 e9x fit? |
08-04-2014, 01:37 PM | #12 | |
298
Rep 4,697
As a heads up, none of these brake calipers(135i or E9x M3) are going to do anything for your street driving aside from make your car ever so slightly heavier/slower with worse handling dynamics, and much more expensive brake maintenance.
08-04-2014, 01:43 PM | #13 | |
Rep 306
and if your statements are right (which they are because yes it's true that they are heavier) why do they make bmwp brakes? |
08-04-2014, 01:56 PM | #14 | |
Rep 12,565
For the same reason they make a performance spoiler, it looks nice and it sells! If you want to alleviate any fade or potential fade, just get better pads and higher temp fluids. And even running race pads on a street car is stupid since they'll never reach optimal temps so they'll bite worse. And those in-between "dual duty" pads are just the worst of both, aggressive but way more brake dust and squeal. Get a good street pad like PFC Z-rated and run Motul 600 and you're good to go. If you want the bling, go for the Performance Brakes. |
08-04-2014, 01:59 PM | #15 | |
298
Rep 4,697
BMW makes the BMW P brakes to make money. Anyone who needs an upgrade and is serious about getting an effective product gets a proper big brake kit made by companies like Brembo(not the only choice).
08-04-2014, 02:00 PM | #16 | |
Rep 306
08-04-2014, 02:02 PM | #17 | |
298
Rep 4,697
Fortunately engine braking was sufficient to prevent me from going over the side of the cliff. To say they don't GAF about how you drive on the street would be putting it mildly.
08-04-2014, 02:05 PM | #18 | |
Rep 12,565
If it's fade, then get better pads and higher temp fluids. If it's uneven pad wear, just learn to do a proper bed-in after your next brake job and avoid any slotted or drilled rotors. Rears tend to wear unevenly because DSC will apply brakes during slip but again, how often is DSC kicking in during a normal commute? |
08-04-2014, 02:35 PM | #19 | |
Rep 306
08-04-2014, 02:42 PM | #20 |
Rep 12,565
What area of performance? Shorter stopping distance? If so then look to tires, not brakes. Resistance to fade? Get pads with higher temp resistance. If you want better initial bite, look at Hawk street pads or a brand known in this regard (although Hawk pads dust like none other).
08-04-2014, 03:41 PM | #21 |
Rep 4,040
130i/330/z4 e89 330mm rotors and 130i Caliper carriers may be a more sound plan of upgrade for a 128i/125i than 135i brakes.
I do like my 135i brakes for the aesthetics and the feel they gave me compared to my worn out rotors and pads.
08-05-2014, 01:33 AM | #22 |
Rep 306
And regarding rotors what's the best brand that I should go for or stock will do? And should i buy 130i calipers too or mine will do?
