02-17-2012, 08:03 AM | #1 |
Rep 77
Active Autowerke Strut Brace Just Arrived
Looks great - will be installing shortly and will update with install pics.
2012 135i M Sport, LeMans Blue/Black int with Poplar - PPK, Dinan Front Sway, BMWPedals, Active Autowerke Strut Brace, KM11 for winter and VMR 718for summer.
02-17-2012, 09:42 AM | #2 |
Rep 77
Install Complete - approx. 10 minutes
Remove two 13mm nuts and loosen one on each side. Install brackets, without having to touch the existing diagonal braces. Use the supplied hardware to mount the brace, and you're done.
VERY high quality, perfect fit.
02-17-2012, 10:25 AM | #5 |
Rep 77
I'd be lying if I said that I felt a big difference... but I haven't driven it very hard since install is only a couple of hours old. It sure looks good though.
02-17-2012, 10:38 AM | #6 |
Rep 639
Very nice! Appears to be a well made and engineered strut bar. If I didn't already have the BMW Performance strut bar I would be insterested in one.
2009 BMW LeMans Blue 135i/Dinan Stage 2 tune/Alufelgen SF-71s/M3 suspension components/Koni Sport adjustable dampers/ETS FMIC/M3 paddle shifters/Alpina B3 TCU flash/VRSF charge pipe
02-21-2012, 11:22 AM | #9 | |
Rep 828
If you're running stiffer shocks/springs and bigger bars, you're transferring more energy (read flex) into the chassis of the car - they kinda go hand in hand. The fact that we've got stock braces to the firewall already, I don't see much benefit on the street if at all. On a track with a fully tuned suspension? Definitely. My STi benefitted greatly on the street from both the front and rear strut bars. But that chassis has a lot of flex and I had super-stiff susp. mods done.
///M
02-21-2012, 01:44 PM | #10 |
Rep 556
As Brahmzy said on the stock suspension not so much. The purpose of the strut is to eliminate flex in the chassis allowing the suspension to accurately place the wheel on the pavement. In order to reduce NHV using run flat tires BMW's suspension engineers specified very soft stock rubber bushings in the suspension, which provide way more flex than the tiny amount caused by chassis deflection.
02-21-2012, 02:04 PM | #11 |
Rep 77
As OP, I agree with both posters immediately above - for me, it is engine compartment bling. Hope that doesn't offend.
03-03-2012, 10:08 AM | #13 |
Rep 77
Shipping weight was 6 pounds, so take away perhaps a pound of packaging and I'd approximate it at 5. Sounds about right from what I can recall, and it is all aluminum.
03-03-2012, 11:46 AM | #14 |
Rep 1,711
Thanks. I just ordered it. Its not cheap for the strut brace, but i think its worth it for some of us who track 135i. There is a lot of stress on both strut towers during hard cornering and this strut brace should reduce it and stabilize the front suspension.
03-05-2012, 07:36 AM | #16 | |
Rep 77
http://store.activeautowerke.com/act...race-p210.aspx
03-05-2012, 08:47 AM | #18 |
Rep 77
No worries, I'm there for you buddy. (I'm not one of those guys that yells "Search!!" everytime someone asks for something.)
03-05-2012, 10:39 AM | #19 |
Rep 148
03-05-2012, 12:22 PM | #21 |
Rep 1,609
Looks great but does it perform as good as it looks? I may consider to buy one myself.
03-08-2012, 11:55 AM | #22 |
Year One of the 1
Rep 87
I was thinking this same thing when I asked. I have a 'Vert and there is obviously a bit of cowl shake despite BMW's being better than most in this department. Seems to be more on the 135 than my old 330 though I may just be imagining it. Will this help at all to improve rigidity or would it just be a waste of money?
