06-04-2017, 04:08 AM | #1 |
Rep 2,186
Di & LPFP restriction Line
So my di pump was always on the limits and dipping below 10 on the jb4 scale and as low as 7
While I was having a good look at an old di pump on the work bench I had a good look at the inlet and found that it has a very restrictive filter. But before removing the filter and not running one I went out and brought a 10 micron 175gph filter from earls and installed it on the car, which will make it an overkill in term of filtration but no such thing as over filtration unless it causes a restriction. At the same time I had a good look at the stainless lpfp line and it has 2 very restrictive bends which I was not fond of and after measuring them I found them quite smaller than the inlet port on the di pump. I went off to earls and we came up with the new line and the results are pretty impressive My di pump never dips below 10 and the lpfp line pressure is nice and solid This worked for me, its up to you if you want to try it and at your own risk and responsibility and any part of the fuel system should be worked on by a competent mechanic. This is with di filter In place http://datazap.me/u/martymil/log-149...ta=1-4-5-10-17 This is with filter removed and 10 micron filter installed under the car http://datazap.me/u/martymil/log-149...ta=1-4-5-10-17 This is with the stainless LPFP line replaced with the new one, I haven't been able to get to the track yet for a proper log but you can see there is a slight improvement, any improvement is good http://datazap.me/u/martymil/log-149...=1-4-5-9-10-17 Last edited by martymil; 06-10-2017 at 08:15 PM.. |
06-04-2017, 03:19 PM | #4 |
Rep 2,186
No but the difference would be insignificant as the parts are alloy and rubber
This should be the first mod on the list of any high powered bmw's I wonder if this would prevent the amount of dead hpfp or fix the ones that suffer low di pressures due to the highly restrictive filter Last edited by martymil; 06-04-2017 at 03:43 PM.. |
06-05-2017, 12:26 AM | #5 |
Rep 2,186
Some more improvements today
Drilled out the fuel rail this is straight 98 mind you Check out the timing on this log from the dyno http://www.datazap.me/u/martymil/log...25-26-27-28-29 Since the timing was so good we pumped another psi into the top end |
06-05-2017, 06:21 AM | #6 |
Rep 92
stock knock tables, fine tuning, restriction free boost circuit, improved traction on 1M...
good numbers, Marty. timing is perfect, drag times are great. and there is a lot of room. |
06-09-2017, 11:16 PM | #8 |
Jedi samurai ninja turtle
619
Rep 3,021
Drives: X3 M40i 2018
Impresssive finds here mate.
06-28-2017, 03:03 AM | #13 |
Rep 2,186
Definitely is, the restriction is the filter and lpfp sensor stainless line
JD75 has the new line but your going to also need the fitting from speedflow to join it to the stock factory line http://speedflowdirect.com.au/itemdetailspage/46253 Last edited by martymil; 06-28-2017 at 03:10 AM.. |
06-28-2017, 07:17 AM | #14 |
Rep 541
Drives: 2008 135i AT Monaco Blue
You guys are true pioneers on this platform. It's incredible to see the improvements still flowing (pun intended haha) like this.
06-28-2017, 06:19 PM | #15 |
Rep 2,186
I'am always exploring new things and working on new developments as this platform is so underrated
12 months ago it would have been laughable to try to get 360rwk on pump fuel alone, now it can be easily achieved I have some new ideas being tried in the next few weeks, keep you guys posted Last edited by martymil; 06-29-2017 at 12:16 PM.. |
06-29-2017, 03:41 AM | #16 |
Rep 541
Marty have you got a list of your mods documented anywhere?
What turbos are the 98RON results based on?
06-29-2017, 10:31 PM | #20 |
Rep 1,140
Drives: N54 135i 6MT
How much is Justin charging for these lines Marty?
06-30-2017, 12:23 AM | #21 |
Rep 491
