03-08-2023, 01:38 PM | #1 |
Rep 111
shocks springs. anything else while I'm there?
Hello 1 addicts
I have a 135i dct. Planning to go with Joni and eibach springs. While I’m under there, any other recs for suspension wise. This is a street mostly setup. M3 control arms/ sub rage inserts? Hope it won’t be too much of a task. Any other recommendations? Thx |
03-08-2023, 03:31 PM | #2 |
Rep 324
Here is a list of some wear items I found in another thread
https://www.1addicts.com/forums/show....php?t=1447013 The sub frame inserts are cheap and easy while you are there |
slowbutsure18.00 |
03-09-2023, 12:48 AM | #3 |
Rep 599
Maybe some other shock mounts. TC Kline recommends Power flex (which I have) and I know others have gone non-OE too. The OE spec fails.
If you're ever going to do the M3 control arms, now's the time. The lower mount is different, so if you don't do it now and decide to do it later, you'll need to replace the shocks again. |
slowbutsure18.00 |
03-09-2023, 12:24 PM | #4 | |
Rep 111
M3 Control arms. Subframe inserts Thanks! |
Almuliman562.00 |
03-09-2023, 03:21 PM | #5 |
Supreme Allied Commander
4010
Rep 55,390
Drives: F80 M3
03-14-2023, 12:40 PM | #6 |
Rep 111
Ok Do I also need dinan camber plates?
I’m also upgrading to m3 control arms which already has more camber I think 1.5 degrees of camber added. Do I still need the dinan camber plates? Thanks in advance |
