      02-26-2020, 07:32 AM   #1
Greenarcher707
Greenarcher707's Avatar
14
Drives: 2009 135i
2009 BMW 135i  [0.00]
Lighting Question
So recently I had my water pump and thermostat replaced (broke down while I was driving so had it towed asap) while I had my hazards on I noticed the left tail light wasn't working for hazard or turning. Weird so I had the bulb replaced, still no dice. Then a day later my left corner light stopped working. SMH. After that my right headlight stopped working too. Crap. Today I'm getting the control unit replaced for the headlight. Will that fix the other two that are not working or is that a different circuit altogether? So tired of dumping money into this car.
2009 135i M Package
Niche Targe Anthracite 18x8
BMS Cold Air Intake
Evolution Racewerks Charge Pipe
Solowerks S1 Coilovers
      02-27-2020, 06:58 PM   #2
mdk135i
Drives: 2009 BMW 135i
might be the footwell module failing. Dont start replacing things without properly identifying the issue.
      02-28-2020, 05:13 PM   #3
Greenarcher707
14
Drives: 2009 135i
Is that hardware or software? Sorry I don't know a lot about these cars. Thanks for your help.
2009 135i M Package
BMS Cold Air Intake
      03-02-2020, 03:34 PM   #4
mdk135i
hardware that has been known to fail. if you have scan tools it helps track down any fault codes.
      03-05-2020, 07:26 PM   #5
Greenarcher707
14
Drives: 2009 135i
I only have Carly for BMW. I'll try it and find out if it can scan error codes as good as other scan tools.
