06-15-2011, 05:42 PM | #1 |
Rep 10
4 modes of the 135i DCT?
I don't have a 1 yet, so please help me understand something-
It appears there are four modes to the DCT: D (sport button off) S (sport button off) D (sport button on) S (sport button On) Is that correct? In my test drives I couldn't really get a feel for all 4 combinations. I'd be curious to hear how readers would characterize them. Thanks! |
06-15-2011, 05:51 PM | #2 | |
Rep 611
S - Car basically holds the revs higher although still controlling all of the shifting...So it will downshift sooner and upshift later. Basically this is more for the track...seems ridiculous to use for daily driving M- Manual mode...this is where you have to shift yourself. You can either do this by the paddles on the steering wheel or by the shifter. The only time the car will shift is if you let the revs drop below 1k it will automatically downshift...or if you let the car hit the redline it will automatically upshift. Sports Mode - This for any mode basically makes it so you have sharper throttle response...essentially say you push your pedal down 1 inch...with sports mode off the throttle will be at 30%...with sports mode on the throttle will be at 50% if that makes sense.. Also sports mode adds quicker shift times to any of the modes. You will be getting very fast shift times with this mode engaged.
2011 AW 135i - DCT - M Package - BMW Performance Suspension Kit - Berk Street Midpipes - Evolution Racewerks FMIC - JB4 - BMS Intake - BMS Downpipes
06-15-2011, 06:44 PM | #3 |
Rep 1,334
"S" basically changes boost scaling so tip-in is more abrupt and hits earlier. It also makes DCT gear shifts faster and harsher. The new DME has made the scaling between "D" and the "S" button musch more apparent. It was scaled closer on earlier cars. Hitting the lever over to "S1", alone, shifts later and holds revs but does not shift as hard as "S" and tip-in is similar to "D" (It won't feel that way since you're always on lower gears most the time based on load). If you hit the lever to "S1" and have the "S" button pressed it's just a combination of all those attributes...and it kills gas :P
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
06-15-2011, 09:16 PM | #4 |
Rep 10
ok, duh- FIVE modes counting manual.
I'm not sure what "tip-in" refers to. Also didn't notice shifts in "sport" being faster--you mean that "sport"-off inserts extra lag between gears to make the transitions gentler? Wow. Plain "D" seemed plenty fast. Thanks! |
06-16-2011, 07:30 AM | #5 | |
Rep 1,664
Drives: E82 N55 DCT
D sport off D sport on S sport off S sport on M sport off M sport on The car also behaves slightly different, in terms of not cutting power, when the traction control is in DTC mode or with the traction control off.
06-16-2011, 07:39 AM | #6 | |
Rep 1,664
Drives: E82 N55 DCT
Just a little test for yourself: Put the car in Manual so that it won't shift on its own until redline, and keep sport OFF. Accelerate down the road in 1st gear and then about halfway through the RPMs turn the sport ON. You will notice that the throttle is more responsive to your input. You can try this in each gear. Another test: Put the car in Manual again with sport OFF. Drive up to about 4500-5000 rpm in 1st gear, and shift up to second, take note of the little bit of lag. Now turn sport ON and drive up to about 4500-5000 rpm in 1st gear and shift up to second... hear that blurp in between shifts? It will feel a lot more aggressive. The blurp is extra fuel in between shifts. BMS has proven on a dyno that there is no loss of power as long as the car is shifted around 6000 rpm through all the gears. If you ever install an exhaust and downpipe, that blurp becomes a pop when the exhaust burns off extra un-burnt fuel.
06-16-2011, 02:31 PM | #7 | |
Rep 1,334
with the new DME/DCT updates, or if you purchased a newer car post 02/10, makes the DCT shifting speeds on "S" less apparent. mine used to change harder and louder with nice obvious exhaust blips on "S". Most of that is gone with the updates but it still shifts faster than regular "D" mode.
03-18-2019, 06:33 AM | #8 |
Rep 9
Resurrecting an old thread - but just got my 2011 135i DCT a week ago and trying to understand it all.
Forgetting for a minute about the "Sport Mode" button, is the "M/S" position on the shifter a single mode incorporating rowing your boat yourself with a measure of sportiness in the process (i.e., sort of "M+S")? Thanks. |
bobdavisnpf99.00 |
03-18-2019, 08:46 AM | #9 | |
Rep 894
S= sport automatic M= manual
03-27-2019, 06:20 PM | #10 |
Rep 2,232
M is for you to change gears yourself either by using the paddles or flicking the gear changer (selector, knob, whatever) up or down. S on the drive selector will be the same as M, but the car changes gears itself, holding the revs higher typically.
What no one has mentioned yet, and what really annoys me is the combination of these modes (any, but I usually drive with sport mode on in just regular D) with either the DSC on or off (single regular press of button). Even if I go sport mode on, and M (manual shifting), the throttle response is super delayed and lazy. I really hate this as I'm trying to have a bit more fun and let the car get closer (closer, not to. Like 6 or 7/10) to the limit but the throttle response is DEAD. Dealer has always maintained this is normal (a "safety feature" even) but makes no sense to me. /EndRant |
03-28-2019, 04:05 PM | #11 | |
Rep 2,232
03-28-2019, 10:08 PM | #12 |
Hapless Noob
99
Rep 125
Ahh the DSC button - one more feature I have not even ventured on to yet. I'll try your described sequence, bet I hit that same "safety feature" ha ha
03-31-2019, 02:48 AM | #13 |
Rep 7,224
Only 'mode' for me: gear selector to the left, sport button pressed, and shifting with the paddles. Not as engaging as a standard manual, but an advantage is faster shifting. Best I can do in my current state, and have grown to love the DCT.
Dackelone10538.50 |
03-31-2019, 04:04 AM | #14 |
Rep 3,071
D vs Sport Mode vs. Sport Button
* D = Automatic * Sport Mode = shifter to the left. Car uses higher RPM shift point, upshifts later & downshifts earlier. If you want to shift manually, move shifter to left then use paddles or use the shifter joystick. * Sport Button = "Driving dynamics control" which is like an /M mode. Car will use (1) higher RPM shift point (upshifts later/downshifts earlier), (2) Increased throttle response & (3) faster DCT shifting. You can engage Sport Button in automatic or while in Sport Mode to stack them. Personally I prefer Sport Mode shifter to the left but Sport Button off. I like the higher shift shift points, but don't like the increased throttle response from Sport Button. I wish there was a way to get the faster shifting w/out the increased throttle response.
