12-31-2013, 11:25 AM | #1 |
Rep 8,942
Roundel / Badge Questions
Have spent a couple days searching Google, forums etc. and no luck. I am looking to do one of two things:
1. Get a custom roundel for hood with my father's initials as opposed to "BMW" 2. Find chrome letters to match rear model designation to add his initials to trunk lid I have found a number of options for different color roundel with overlays but no truly custom option at Bimmian and others. Also easy to find black, gold, red letters that match factory perfectly but chrome can only find larger or smaller, nothing that is a perfect match. Anyone have any ideas? Money is no object as father is not well and the car is his baby, want to personalize it for him but nothing flashy. Roundel would be perfect because unless you knew it was there no one would ever notice. Thanks in advance for the help. |
12-31-2013, 12:26 PM | #2 |
Rep 363
I have never seen anything customized of that sort besides changing the colors. Your only bet would probably to go to a body shop and see if they could make it out for you the way you want it. A cheaper alternative would be to go to a sign shop and see if they could design and cut a full sticker vinyl with what you want that would fit on the stock roundel. Really don't know of any other way.
12-31-2013, 01:00 PM | #3 |
Rep 2,346
You may have better luck buying stock emblems and having them wrapped by a shop that does vinyl work.
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms |
01-02-2014, 11:56 AM | #5 |
Specialist
1313
Rep 2,708
http://luftkraftfab.com/ will make you the Roundel exactly how you want with whatever you want.
01-02-2014, 11:58 AM | #6 |
Rep 1,557
Drives: F10 M5 & F85 X5M
Have you tried bimmian.com, try giving them a call they might be able to do something like this.
AW F10 ///M5 AW F85 X5///M BootMode3 STG 2///Project-Gamma Intakes///ActiveAutowerke DPs///Maxton-Design Body Kit @MeisterAutosport @RatedMClub @RatedMRally |
01-03-2014, 06:44 PM | #8 |
Rep 8,942
tpowerdinny - thanks for the info! Spoke with luftkraftfab and they are going to make me a one-off. Will modify a stock roundel, repaint it and clear coat it. Didn't seem out of their comfort zone in the slightest. Will post some photos when done, all-in including a new OEM roundel I'm looking at $150-$200 so totally reasonable as far as I am concerned.
01-03-2014, 06:59 PM | #9 | |
Admiral of the Fleet
275
Rep 3,560
01-15-2014, 04:26 PM | #12 |
Rep 8,942
Should be done sometime in the next week or two, told them no rush since I won't have an opportunity to install until February. I am just changing the letters, although all the chrome will now be metallic silver since cannot paint letters in chrome.
@gregthegr8 - i think they can literally do whatever you want. the only difference would be sanding perfectly flat to get a blank canvas or keeping raised areas (BMW, chrome) and modifying other areas. Will post photos asap. |
01-24-2014, 07:10 PM | #13 |
Rep 8,942
Haven't seen this in person yet (still at shop) but from the photos these look pretty amazing. Will update once it's in my possession and installed, but won't be for a few months by the time I visit dad and put it on the car. Thanks again for the help.
01-27-2014, 09:36 PM | #15 |
The Crowing
112
Rep 2,005
Let me know how they fit! I feel I might have to copy you.
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback |
04-16-2014, 04:40 PM | #16 |
Rep 8,942
FINALLY got these installed, they look great. Started with an OEM part so the fit wasn't an issue at all. In person honestly look better / higher quality than stock. Couldn't be happier. Thanks again for the help!
04-16-2014, 07:48 PM | #17 |
love to fish!
46
Rep 649
Drives: 13: SG 135i M-Sport Cabrio 6mt
04-16-2014, 08:51 PM | #18 |
Rep 8,942
LOVED it. I just got the front, I didn't tell him we could do all of them because with trunk, wheels etc. the $ starts to add up fast and it's honestly a little aggressive for my/his taste. Everyone at the dealer thought it was the nastiest stealth mod they'd ever seen, all the guys in the maintenance dept were all over it.
