08-06-2019, 05:50 PM | #1 |
Rep 15
M3 Rear Subframe Bushings Rubber vs. Aluminum
Hello. I was looking at these two sets of rear subframe bushings and was just wondering what the difference would be? I noticed one is aluminum and the other is rubber. Is there a better option between the two?
https://www.turnermotorsport.com/p-1...ubber-e82-e9x/ https://www.turnermotorsport.com/p-1...minum-e82-e9x/ |
08-06-2019, 05:57 PM | #2 |
Rep 2,232
Sorta related, but someone is selling a set of Turner Aluminim ones right now if you decide to go that route.
https://www.1addicts.com/forums/show....php?t=1639773 |
08-06-2019, 06:06 PM | #3 | |
Rep 15
08-06-2019, 07:14 PM | #4 |
Rep 3,241
Unless you have smooth as glass roads or this is a track only car, I cringe at how harsh the ride would be with solid bushings.
08-06-2019, 07:33 PM | #5 |
Rep 15
08-06-2019, 07:40 PM | #6 |
Rep 3,241
Then why are you considering solid bushings?
08-06-2019, 07:43 PM | #7 |
Rep 15
08-06-2019, 08:13 PM | #8 |
Rep 367
Search for Whiteline bushings I bought mine from Amazon. Had to wait for them but the best price I could find. I think I found them under E90 chassis designation. Exact same part Whiteline KDT917
08-06-2019, 08:44 PM | #9 |
Rep 6,196
08-06-2019, 09:38 PM | #10 | |
Rep 3,241
I remember life with an old project car I had. Had urethane bushings, Bilstein struts, Eibach springs, bigger rear sway bar, Koni yellow shocks, and caster plates. The thing rode hard. In the beginning it was novel. It got old quick driving through the messed up roads in DC. Eventually, that harshness translated into broken suspension pieces. Won't do that again. |
08-06-2019, 09:40 PM | #11 |
Rep 3,241
I'd go with the first option in your post which are the stock M3 rubber bushings and call it a day.
08-06-2019, 11:19 PM | #12 |
Rep 2,232
08-06-2019, 11:48 PM | #13 |
Rep 648
I have the M3 bushings installed and it really transformed the car without being too punishing. If you could only ever do one mod to this car, that would be one I would recommend.
08-07-2019, 08:06 AM | #14 |
Rep 3,550
I did the same and feel the same as well. The M3 bushings eliminated the rubber band rear end snap and though the ride got firmer it isn't bad even in MN. I think the solid bushings probably actually wouldn't be a terrible ride either, and would be livable, but since the M3's totally did the job I guess I don't see the need to go a step further. To each their own of course, typically my mentality is to go that step further.
08-07-2019, 08:23 AM | #15 |
Rep 2,250
Check with chris_flies .
He went with one brand (I can't remember)....but it was a good price and he said he really liked them.
08-07-2019, 08:34 AM | #16 | |
Rep 15
08-07-2019, 08:59 AM | #17 |
1Addict
3234
Rep 7,895
I noticed no difference in NVH or ride quality between stock rubber with poly inserts, and solid aluminum from bimmerworld.
There was a huge difference in suspension response and rear end stability though.
08-07-2019, 10:00 AM | #18 | ||
Rep 2,232
08-07-2019, 11:26 AM | #19 | |
Rep 904
I got poly, and, while they’re easier to install at home, my shop didn’t really charge me much less to install the 2-piece, so I probably would go all the way to aluminum if I had a do-over. |
08-07-2019, 12:06 PM | #20 | |
1Addict
3234
Rep 7,895
Key thing in all this though is to keep the diff mounts STOCK.
08-07-2019, 12:20 PM | #21 |
Слава Украине!
2317
Rep 2,441
FTFY
08-07-2019, 06:30 PM | #22 |
Rep 904
