11-30-2018, 02:05 PM | #1 | |
Rep 12
BMW E82 powered by N54B30
Okay so here is my 135i. Car is originally from Cali and I have owned this car for almost a year. Now the car has 93 000km on the clock.
The beginning of the story with this car wasnīt all fun and games. About one month after owning the car I started to get limp mode. So annoying. I took the car to the BMW dealer 3 times to fix the problem and yet they had no idea what was causing the limp mode. And so I kept getting the limp mode. Daayeum I was pissed off for the car constantly loosing the power. Finally they managed to find the problem wich turned out to be a leaking injector. Well, here is everything that was replaced after all to fix the problem -All injectors (now I am running index 12 WOHOO!) -All Spark plugs -All Coils -Some vacuum lines -Vanos solenoid valve My passanger side window started to go up and down like a maniac so they changed the -Controller -Cable Harness -Motor -Gasket to keep the moist out After this, the engine pulled like a dream and the window worked no problem. Here are all the options: Quote:
11-30-2018, 03:02 PM | #3 |
Rep 12
First I thought I will keep the car stock. The performance felt great. But you know how it goes. You get used to the power. So I wanted more.
My first upgrade was MHD stage 1 and BMS DCI. Wow what a difference! But... like allways. I needed more powah. I visited VRSF webshop and ordered - 3" cattless dpīs - 7" HD FMIC - silicone inlets - chargepipe The shipping was lightning fast. It only took few days to get everything delivered. I have never done anything by myself to a car, not even changed oil. So why not tune a car to +400 hp. Well fok it. Git īEr Done! The downpipes looked fantastic. Finnish was top notch quality! These fellows were not fun to install. The V bands gave me a headache. You really need to get them just right. Well, next time it will be easier now that I know how to do it. Exhaust sound after replacing them cats with these 3" bad boys? Sounds fantastic! Okay my car has also the BMW Performance Exhaust wich ads pretty sweet burples and rasp to the hi revs Next thing was to install the intercooler. Compared to the DPīs this is easy. Espacially if you have extra hands with you. Special thanks goes to Masander for the help. The VRSF 7" HD makes the stock FMIC look like a toy. Sure, it weights much more over the stock but hey thatīs the price you need to pay for the performance. The IAT hardly raise at all especially now that it is winter time The CP was high quality aswell. Easy to install. Just remember to tighten those meth bung plugs and you will be fine. Those hose clamps were a litle bit too big but it didnīt matter as the fitment was still very tight. VRSF provides great quality. Thanks to Tiago @ VRSF After I installed all the FBO parts I upgraded MHD Stage 1 to Stage 1+. The car pulls way harder than stock. The boost builds up much faster too. Great succes! Last edited by N54B30; 11-30-2018 at 05:09 PM.. |
Fakemike368.50 |
11-30-2018, 03:28 PM | #4 |
Rep 12
My carīs tire setup was Michelin Pilot Sport 4 in the front and Pilot Sport 2 at the rear. I smoked the shit out of those Pilot Sport 2ī by making burnouts. After that I got them replaced with Pilot Sport 4. Those PS4 are awesome. When you do a stand still launch with these PS4 they literally grab into the tarmac. You could do 0-60 laucnhes under 5 sec all day with them. They are very good on a rainy surface aswell. Thats the reason I chose the PS4 over the Pilot Super Sport.
I also got my stock LPFP replaced by Walbro 450 stage 2. I took this picture from google bc I didnīt find a picture of my own similar pump. My next plan is to get a custom tune from PureBoost and run RE85. I also took my car to wallnut blast. Here is before. Look at that goop! I am pretty sure the intake works much better looking like this. |
Matticus913474.50 |
11-30-2018, 06:04 PM | #5 |
Rep 3,722
Oh mah-gosh... those before and after pictures are.... stunning lol. Also really makes me want to port them out, just look at that texture!!!
"Tobias" 2013 135i ///M-Sport 6MT Pure Stage 1 XDI 35 HPFP 404whp/440wtq |
12-02-2018, 11:15 AM | #6 |
Rep 12
12-02-2018, 11:17 AM | #7 |
Rep 12
12-02-2018, 01:02 PM | #8 | |
Rep 46
Great stuff with the engine work! Not too many 135:s around in Finland.
You know how it works when you start doing exterior mods! You will keep finding things that could be improved and it gets expensive. I thought I'd just change the headlights and be done with it. "Just need this one last thing to finish it off..." |
12-02-2018, 04:55 PM | #9 | |
Rep 12
12-03-2018, 12:31 AM | #10 |
Rep 89
Looking forward to meet again!
Pic related. [IMG] View post on imgur.com [/IMG]Team Titansilber had a very unofficial family reunion last summer. [IMG] View post on imgur.com [/IMG]
Style is engineering that gives you freedom. Chris Bangle |
12-03-2018, 03:36 AM | #11 | |
Rep 12
01-13-2019, 01:58 PM | #12 |
Rep 12
My lights looked like this. Something had to be done. So I sanded them This is how they look now My BMW Performance Exhaust looked like this so I had to do some cleaning and polishing Now they are looking better Mirror looked terrible. It annoyed me everytime I was looking to the objects losing Now it is all clear and crisp like my 4K television at home Car has been running good. Still going with low boost (about 14psi). But that is about to change. The VRSF bolt ons made a huge difference in terms of power and sound. They still bring a smile in my face when hitting the pedal to the metal. And so far no problems with the bolt ons Next thing should be instalning wheelspacers. I was thinking 16mm rear and 16mm front. What do you guys think? |
01-14-2019, 08:18 AM | #14 |
Rep 265
What grit sand paper did you use for your headlights?
Also what size tires are you running? Im running 255/35 in the rear and 12mm spacer is all i could fit without rubbing. |
01-15-2019, 12:50 PM | #15 | |
Rep 12
I am running 245/35/18. I think I should be fine with 14mm or 15mm spacers in the rear and 12mm in the front |
01-16-2019, 11:15 AM | #16 |
Joint Chiefs of Staff
24193
Rep 190,805
Awesome!
01-20-2019, 02:40 PM | #17 |
Rep 12
Engine bay looked horrible
So I did some cleaning today Last edited by N54B30; 01-20-2019 at 03:15 PM.. |
Matticus913474.50 Masander261.00 |
03-29-2019, 03:52 PM | #20 |
Rep 469
Drives: 2008 BMW 135i 6MT
What did you use on the mirror? I have the same thing starting on mine and didn't know you could actually get that to come off.
2008 TSM 135i N54
03-31-2019, 03:53 AM | #21 | |
Rep 89
It is a quite easy fix to do👍
04-04-2019, 11:22 AM | #22 | |
Rep 469
