08-16-2016, 11:23 AM | #1 |
Rep 89
Tire Square Question
I have two sets of stock wheels for my 135i. Does anyone know if the I can square up the front using the extra rears I have with the 245 tires on them?
Thanks, |
08-16-2016, 02:31 PM | #2 |
Rep 351
ET52 stock rears with 12mm spacers will fit the 245/35's. If you're lowered you might have fender clearance issues and need more camber or a fender roll.
Ohlins Road & Track Coilovers / Apex ARC 8's 245/255-35 MPSS / Wagner Downpipes / Wagner EVOII Intercooler / ER Charge Pipe / Forge DV / PowerFlex RSFB / PowerFlex Differential Bushings / MFactory 3.46 Torsion LSD / MHD Flasher
optigrab59.00 |
08-16-2016, 03:39 PM | #3 |
Loves me some MHD!
1857
Rep 1,719
Which stock wheels do you have? I'm curious about the same thing...
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla . . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg Last edited by 1and1; 08-17-2016 at 05:55 PM.. Reason: -thimg, +thing |
08-16-2016, 04:19 PM | #4 |
Rep 750
I'd recommend 10mm spacers over 12, I found the 12's with 255s would rub really bad on the bumper tab. YMMV though depending on your tire brand and size.
08-17-2016, 12:48 AM | #5 |
Boost
1354
Rep 3,692
Drives: 135i M-Sport
I run square M261 rims with ~265mm tires on all four sides with 7mm spacers up front - lowered with -2* camber up front.
08-17-2016, 06:46 AM | #6 |
Rep 89
Mine are the stock type 261 wheels with the M option. I am really curious how much more grip you guys get running the 245's up front.
Needless to say last year I slide off the road when the front washed out on a 90 degree turn. Not sure why bmw put a 215 up front. Is it a noticeable difference in look out front? spxx would love to see a picture of what yours looks like if you don't mind. |
08-17-2016, 05:50 PM | #7 | |
Rep 750
08-17-2016, 11:18 PM | #8 |
Rep 403
Here are details on my square 264 setup: http://www.1addicts.com/forums/showthread.php?t=1170959
Karl.
Stock – 997.2 C2S Coupé • Carrara White / Cocoa • Adaptive Sports Seats • PDK w/SC • PSE
Mods – Front 996-GT2 and Rear 997-Turbo Brake Ducts • 3rd (center) Coolant Radiator • 10mm/15mm Spacers |
08-20-2016, 11:50 PM | #9 |
Rep 475
Drives: 2009 Crimson Red 135i
I'm running a square setup with 255/35 R18s on the 261 style wheels (2 sets of rears). I'm running 12mm spacers from turner motorsports up front, rolled front fenders, and shaved bumper tabs.
TC Kline DA kit with vorshlag camber plates. On track I rubbed a hole in the fuel filler plastic tube in the rear. Anyone else have that issue? As to solutions, I could put maybe a 5mm spacer on the rear, or perhaps some clever way of re-routing the fuel filler? Any ideas? Thanks! -Joe |
08-21-2016, 10:20 AM | #10 |
Rep 1,409
Similar to Joeo -
Previous track setup, and now rain setup: I'm running a square setup with Dunlop Direzza ZII SS 255/35 R18s on "261 style" wheels (2 sets of rears), with 10mm spacers up front, rolled front fenders, and shaved bumper tabs. New track setup: I'm running a square setup with Nitto NT-01 255/40 R17s on "68 style" wheels (2 sets of rears), with 10mm spacers up front.
08-21-2016, 11:42 AM | #11 |
Rep 475
I'm running Toyo R888s all around. dcaron9999 - did you have any issue with the fuel filler being rubbed in the rear? Are the 68 style rims from an E46 M3? Same offset as the 135i wheels?
Thanks. -Joe |
08-22-2016, 09:32 AM | #12 |
Rep 89
Does anyone know if I can fit 255's in the rear on the stock wheels without using spacers.
I got the spacers for the front 10mm and will be putting 245's in the front. |
08-22-2016, 09:45 AM | #13 |
Rep 475
255/35 R18s fit fine on the rear with the stock suspension.
08-26-2016, 04:38 PM | #14 |
More Boost?
59
Rep 283
08-26-2016, 05:12 PM | #15 |
Rep 2,232
08-26-2016, 07:40 PM | #16 | |
Boost
1354
Rep 3,692
08-31-2016, 11:38 AM | #17 |
Rep 89
I only got the 10 mm spacers for the front. I am assuming I don't need them for the rear and they wouldn't work anyway in the rear with stock suspension and 255 tires on the stock rear wheels.
Does anyone know if that is correct? |
08-31-2016, 03:06 PM | #18 | |
California-bound
385
Rep 1,480
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 |
08-31-2016, 08:10 PM | #19 |
Rep 475
Thanks Ginger_Extract - I went with a 3mm spacer, and I'm going to slightly modify the filler pipe. That's my plan anyway.
-Joe |
10-07-2016, 07:52 PM | #20 | |
Rep 89
10-07-2016, 08:23 PM | #21 | |
Rep 1,428
10-07-2016, 08:59 PM | #22 |
Bergspyder
1469
Rep 1,212
Could you run a set of rally or winter tires on 4 fronts???
