      08-22-2018, 06:19 PM   #1
boostpak
Drives: bmw 125i coupe
Swapping front headlights. Help!
I am wanting to swap my 2010 128i non sport headlights as I want halos around mine and they aren't capable of adding them. So I've found a found a set from a 128i convertible that aren't xenon headlights (see attached)Name:  $_20.JPG
They would be a straight swap. Wondering would I be able to put halos on these front headlights even if they aren't xenon?
Also thinking of swapping the rears to (see attached)Name:  jf20g21bbbrtphxar5fttrjrd.jpg
as I have the stock ones. They are from the convertable too. Is it a straight swap to the coupe? I've read there will probably be coding involved?
Thanks any help appreciated.
      08-23-2018, 06:11 PM   #2
boostpak
bump
      08-24-2018, 11:18 AM   #3
Droptop986
Droptop986's Avatar
37
Drives: 2009 E88 135i
You could probably add aftermarket halos but would need to open the headlights up and run the wires to the running light bulbs I would think
      09-22-2018, 09:03 AM   #4
mechavore884
mechavore884's Avatar
Drives: the fat mobile
+1
to be fair its probably a really tall order...Halo's can be found cheap (and I doubt any coding is needed) but you will need to bake the headlights to open them up for the install...potentially may be cheaper to find some Umnitza (forgot the spelling)
6MT/CDV Delete/Injen Intake/berk race exhaust/ Cyba Scoops/ECS cryo rotors/Axxis ultimate pads/H&R coils/BBS LM-esque lol/BMW PE front/whiteline sway/and did i mention 2200 at 1 ohm ...eyeing the auto diff currently
