      08-06-2018, 07:34 PM   #1
dkat
Drives: 2000 BMW Z8, 2011 1M, 2020 Por
Maintenance/Service Question
I recently purchased a 1M with about 7,500 mi. Added about 500 miles since purchase. Seller performed a dealer oil service @7,400 miles. I am not usually a fan of BMW dealer service, but the airbag recall has not been done. So if I bring it to BMW, what other service/PM items do you recommend to be performed? Seller did not keep service records. Fluid changes? Software updates? Key fob OBD fix?
Any advice would be appreciated.
      08-06-2018, 08:06 PM   #2
10"
10"'s Avatar
Drives: orange BMW 1M.
Get the dealer to try and scan your key to access maintenance history.
The list of maintenance items is otherwise long and you'd need to know what was done and what wasn't...IMO.
don't read this. too late...
      08-06-2018, 08:48 PM   #3
nachob
Like he said, see if they can scan the maintenance history. This is a 7 year old car despite the miles. I would change the brake fluid, transmission, diff and even the coolant. The fluids that sit, collect condensation etc that is never really burned. When I bought LT5 gearbox fluid in 2011 for my first of 2 1Ms, it had an use-by date on the bottle of July 2016 or 5 years after manufacture. The brake fluid should be changed every two years. Coolant is 7 years old now. I would also buy a bottle of fuel system cleaner as fuel that sits in the tank a long time can also break down into gum and varnish. Fresh fuel helps break this stuff down too but can't hurt to throw a $12 bottle of BMW Techron fuel system cleaner.
Congrats on the new car.
10"4974.50
1mGator143.50
      08-06-2018, 10:04 PM   #4
10"
10"'s Avatar
just realised you're in NY as well. sent you a PM!
      08-07-2018, 09:45 AM   #5
dkat
Thanks for advice.
      08-15-2018, 08:01 PM   #6
vasmir
eh
vasmir's Avatar
129
Drives: 2011 E82 M, 2016 F25
concur 100% with nachob
Also, the other recall that applies is the battery connector... make sure this was (or gets) done.
Battery Cable Connector Recall for BMW 1 Series (E8X), 3 Series (E9X), Z4 (E89)
BMW Safety Recalls
      08-15-2018, 10:11 PM   #7
etr2016
Drives: 1M - Black
I didn't know BMW made Techron fuel cleaner. Is this a dealer special?
2011 - 1M - Black
2007 - Honda S2000 - Black
2020 - Lexus GX460 - Black
2022 - Lexus ES350 - Black
      08-15-2018, 11:47 PM   #8
ayao
Thread killer
642
Drives: 1M
https://www.e90post.com/forums/showthread.php?t=1362709
etr201695.00
      08-16-2018, 04:11 AM   #9
10"
10"'s Avatar
They're just relabeling Chevron Techron. Literally....much cheaper and easier to just buy Techron at a gas station....lol
      08-16-2018, 08:10 AM   #10
dkat
Car is at dealer now. Did not know about battery connector recall. Emailed service adviser. waiting for response
      08-21-2018, 08:31 PM   #11
doug_999
doug_999's Avatar
2542
Drives: 2011 1M/2021 992/2023 X3
Actually, per Mike Miller, the trans and diff fluids are changed based on miles only.
And while coolant is a good idea, BMW dealers are really hesitant - especially do to it right (and get it all flushed). But you should still do it.
Just don't waste your money on the trans and diff fluids.
And if you email Mike Miller, he will send you his lifetime maintenance schedule.
2011 1M, Black loaded sans sat radio
2021 911 C4S Gentian Blue, manual
2023 X3 M40i - loaded sans Park Assist
