08-31-2007, 03:53 PM | #1 | ||
form follows function
38
Rep 838
Electronically Controlled Limited Slip Differential
Good, bad or ugly?
Opinions? Does anybody have any experience with electronic (simulated) LSDs? What diff is going to be on the M3? To the best of my understanding i'm not impressed with the potential. An open diff will let one wheel slip for days and not even move the other one if the friction is right (or lack thereof) so in essence you have a system that will stop one wheel from spinning out of control but does nothing to aid in gaining additional traction. It can't really be replacing this.. Quote:
08-31-2007, 04:00 PM | #2 |
Rep 18
I wouldn't call the traction control system a "limited slip differential", exactly. A limited slip differential generally transfers power across to the other wheel with very little loss of energy, whereas applying the brakes converts that motive energy to heat. Sure, some heat is generated in a real limited slip, but not nearly the amount of heat generated in a traction control system.
DSC includes the capabilities you're describing, and I've used it on the track. It works pretty well if you already know how to modulate throttle for minimal wheelspin, but if you go too far and it can't stop wheel spin with just a brake application, it will cut back power from the engine. If anything, it serves more to preserve your tires than to make you go much faster.
08-31-2007, 04:34 PM | #4 |
38
Rep 838
diaz, i am not referring to the traction control system, although it does have some of the same functionality now that you mention it. but because the 135i will not have a true mechanical lsd (which we would all like, and would do as you say, transfer power away from the slipping wheel as opposed to simply wasting torque production) they have mentioned incorporating an electronically controlled limited slip differential (being a speed sensitive lsd, like viscous fluid unts)
08-31-2007, 04:53 PM | #6 | |
Rep 18
08-31-2007, 05:52 PM | #7 |
Rep 582
The problem with the electronically controlled limited slip differential system is that it relies on traction control. So, typically if someone wants to have some fun w/out having power cut by the traction nannies, the first thing a driver needs to due is turn it off. It remains to be seen if the turning off the traction control (DSC) also turns off the electronically controlled limited slip differential. If it does, then you're back to a 100% open diff.
With any luck the 135 will let you disengage the traction control, while still getting some benefit from the electronically controlled diff. I suspect however, that nothing beats a mechanical LSD and 135 buyers will have to add an aftermarket LSD to their tuning lists. Funny thing is that BMW started welding something on the diff housing (not quite sure how this works) to make it difficult to simply swap the diff guts. Which increases the cost of the swap, and requires core charges... wonder why they did that!?! -Mahlzeit |
08-31-2007, 05:52 PM | #8 | |
Mr. Happy
Rep 479
My ZHP had DSC. When it kicked in, the engine was retarded and the car slowed. No torque was transferred. It sucked. The 135 ELSD is different and works even when DSC is turned off. |
08-31-2007, 05:55 PM | #9 | |
Mr. Happy
Rep 479
08-31-2007, 06:23 PM | #10 |
Rep 158
What would happen if one attempted to do a burnout in a E-LSDed 135i with the traction control turned off but the E-LSD still turned on? It seems to me that such treatment of the E-LSD could result in very very expensive repair bills very quickly.
08-31-2007, 07:06 PM | #11 |
Rep 524
No, just disatisfaction and wear on the brakes. A real LSD is a must with one of these cars...
1973 Porsche Carrera RS 2.7 Carbon Fiber (240hp & 1,890 lbs)
08-31-2007, 07:10 PM | #12 | ||||
Rep 18
08-31-2007, 07:17 PM | #13 | |
Rep 18
08-31-2007, 07:29 PM | #14 |
Santa Fe Concorso
103
Rep 2,984
The ELSD cannot be disabled, AFAIK, and still works when all the other electronic drive control doodads are turned off. I'm actually beginning to warm up to this technology, but I'll just have to wait and see.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
08-31-2007, 09:57 PM | #15 | |
Mr. Happy
Rep 479
In other words, there will be no power retardation with this system if you turn off the DSC but the ELSD will assist. This is different than the systems to date and the configurations you cite above. The result will be a semi effective ELSD despite the open diff configuration that will send up to HALF of the available (and UNRETARDED!) torque to non spinning wheel. Sure, it's not a full mechanical LSD, but it's certainly vastly better than nothing! I am in La Costa - you want to sit down, have coffee and discuss it? |
08-31-2007, 10:03 PM | #16 | |
Rep 18
08-31-2007, 10:10 PM | #17 | |
Mr. Happy
Rep 479
I'm quite certain the ZHP, a very sporty BMW model had three assist modes - (1) power retard ON/brake retard ON, ABS ON (DSC) (2) power retard OFF/brake retard OFF, ABS ON (DTC) (3) all assist off [edit] I checked. It appears the DTC mode (#2) simply raises the limit for retardation to allow some slip, for example, in snow conditions. |
08-31-2007, 10:24 PM | #18 | |
Rep 18
Yeah, I changed my post to reflect having read that about DTC a moment after posting that. I'm pretty sure ASC+T still eases back on engine power. Maybe the 135i traction control won't be as intrusive as previous BMW iterations, but regardless, I would still call this "traction control" and not "E-LSD", which is a bit misleading.
08-31-2007, 10:47 PM | #19 |
Mr. Happy
Rep 479
iDiaz, sorry to come back at you again, but "Traction Control" is a very generic word that simply means any management of wheel spin via power retardation or braking that serves to return traction. DSC is traction control.
BMW's ELSD appears to be specifically designed to function much like an LSD by specifically causing torque to be sent to a wheel that isn't turning enough. I'll let it rest here, but I think the term is quite appropriate. Probably best to wait and see it work in practice. It might be great, and it might be a total crock. :iono: Experience is so much better than conjecture! |
08-31-2007, 11:45 PM | #20 | ||||
Rep 18
All good, mang. :smile:
I've noticed my MINI controlling traction under power without throttling back the engine at Buttonwillow. I modulated the throttle enough for a hair of wheelspin on exit coming over the hill after the Cotton Corners, when I forgot to turn DSC off and noticed something different and the DSC light flashing out of the corner of my eye. It just braked the wheel to stop it from spinning the tire, converting that kinetic energy into brake heat instead of using it to propel me forward, something a real LSD would have done by actually biasing torque effectively. Quote:
09-01-2007, 01:58 AM | #21 |
Rep 611
I am not sure if this helps:
From Edmunds Insideline http://www.edmunds.com/insideline/do...hotopanel..1.* We would prefer a proper mechanical limited-slip differential to the SRT-4's traction-control-based arrangement. With the so-called Brake Lock Differential, a wheel speed sensor detects wheelspin and applies the brake to that side to force the transfer of power to the other side. As a rule, we think that applying the brakes to make forward progress is the wrong approach. |
09-01-2007, 10:05 AM | #22 | |
Rep 122
To make things completely confusing, and I'm suprised we have not landed here yet, is BMW's new, electrically actuated, mechanical limited slip they are introducing in their x-drive cars. It is an actual mechanical LSD that uses electrically actuated clutch packs in the LSD to work. Every instance I have seen of the above discussion of E-LSD, eventually gets confused with the ELD (electronic locking differential) that I'm talking about. I have no doubt that the brake management scheme will work better than an open differential for 70% of drivers in the majority of normal driving situations. I have a hard time beleiving it will perform any where near a true LSD in sport driving applications. We shall see. I believe Land Rover and other 4X4 applications have used this braking scheme as well. It works, but does not replace LSDs, or locking differentials by any means. It is just better for the "suburban wheelers" than open diffs. I assume BMW is trying to do the same for the "suburban racers" as well. |
