      01-11-2022, 02:06 AM   #1
elijdh
Drives: 2008 BMW 135i
Exclamation HELP PLEASE! A ton of codes on car after getting service + downpipes installed
Hi there!
So I got a service done to my car:
Replaced Turbo Pressure and Return Line O-Rings
Replaced Coolant Line O-Rings
Replaced Bank 2 Sensor 1 O2 Sensor
While the mechanic was up there I figured get him to install my catless downpipes as well. Also did my spark plugs (NGK Stage 1) and an oil change.
Before I got this done all I had was the O2 Sensor code and 2B28 (Fuel tank ventilation system and purge air system, micro-leak. I wasn't burning oil, had a very minor leak from turbo lines which is why I did all the o-rings.
Ever since getting this done, I got codes:
2A7A - DME - Camshaft position controller, exhaust, cold start
2AAF - DME: Fuel pump, plausibility
2B28 - DME: Fuel tank ventilation system and purge air system, micro-leak.
2C27 - DME: Oxygen sensor before catalytic converter: System check
2C2B - DME: Oxygen sensor before catalytic converter: System check
2C2C - DME: Oxygen sensor 2 before catalytic converter: System check
2C31 - DME: Oxygen sensor control
2C32 - DME: Lambda control 2
2C6A - DME: Oxygen sensor after catalytic converter: Swapped
2C6B - DME: Oxygen sensor after catalytic converter: System check
2C6C - DME: Oxygen sensor 2 after catalytic converter: System check
2C7F - DME: Lambda control 2
2DEB - DME: Power management, vehicle electrical system
My mechanic said the O2 Sensor codes and the lambda codes are just from the fact that I'm catless now... I don't feel this is accurate.
Can anyone help me with this? The moment I saw all these codes my heart dropped, this car has been an absolute money pit so far and now this.
Help, please!!
      01-24-2022, 06:48 PM   #2
Papa Popov
Papa Popov's Avatar
315
Drives: 2009 128i 6MT
Originally Posted by elijdh View Post
Hi there!
Help, please!!
Part of the O2 sensor's job is to monitor emissions. You'll need a tune to get rid of the CEL caused by removing the cats.
